General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Check engine light
Old Feb 16, 2010 | 03:01 PM
rsk516's Avatar
Check engine light
My check engine light came on on my 02 runner the other day. I took it to autozone today for them to read the code, they said it was a "mass airflow malfunction". The guy suggested I change the air filter (which was due to be changed anyway) and also to spray some carb. cleaner up into the air intake. I did those two things and the light is still on. Any help would be appreciated. I'm planning a weekend trip and was going to drive my runner so I would like to get this fixed by this weekend. TIA
Old Feb 16, 2010 | 03:14 PM
dropzone's Avatar
Fossilized
you can unplug the battery for 15 minutes which will reset the ECU..you will have to redo your radio presets....if the air filter replacement fixed it resetting the ECU should have the light go away...it might come back if it is another issue...
Old Feb 16, 2010 | 03:34 PM
rsk516's Avatar
Ok, thanks for the help. I will try this in the morning.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
