General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Bad wires going to knock sensor!!!
Old Apr 11, 2008 | 06:28 AM
Team420's Avatar
I recently changed the pigtail wires from the knock sensor..I didnt change the sensor itself as I have heard over and over again that its not likely to be the sensor, I do believe this to be true, i think the wires going from ecu to knock sensor connector hav a bad stretch in them... what i would like to know is....
1) Do I need special wire to rewire this?
2) is there any special proceedure?
3) can i cut and splice the bad section...or do i have to go all the way with it?
Any advice would be greatly appreciated, I know these are very sensitive wires and that even the slightest resistance will trigger the code, I am not very experienced with wiring or electrical stuff, and I really miss my truck being able to get from 0-60 in less than an hour!!
Old Apr 11, 2008 | 05:42 PM
Noltz's Avatar
A knock sensor deals with VERY low voltage, I'm sure you know. Make sure you use the same gauge wire but I don't recall ever seeing a specific wire for that application. Ensure clean wires, good soldering & heat shrink to prevent corrosion.
Old Apr 12, 2008 | 09:21 AM
Team420's Avatar
thanks for the tip. Upon further inspection, it appears i need a new harness(ecu side),the wires pull out very easily. gonna try a few yards to see if i can cut one off, any one know if this is something that can be ordered from toyota? Or approx, cost? and do u think this will solve my problem?
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
