General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
air horn wiring diagram needed??
Old Dec 17, 2005 | 02:37 PM
i_rifiyou's Avatar
can someone post the diargam, and what size wire i need to go get.....thanks guys
Old Dec 17, 2005 | 04:04 PM
i_rifiyou's Avatar
Old Dec 17, 2005 | 05:00 PM
i_rifiyou's Avatar
bump??
Old Dec 17, 2005 | 08:34 PM
4x4Lamm's Avatar
Need more info, lots more. I could help you if I knew specifics.
Lamm
Old Dec 18, 2005 | 08:05 PM
i_rifiyou's Avatar
ummmm....an air horn,
i bought this hella air horn, and i want to install it but lost the wiring diagram...(directions).....any help???? i already got the wire 14awg, i just need the diagram......i hope i made it easier to understand
Old Dec 18, 2005 | 08:09 PM
shazaam's Avatar
https://www.yotatech.com/~corey/tech...orns/corey.htm
Old Dec 18, 2005 | 08:27 PM
4x4Lamm's Avatar
ummmmmmm, loose the attitude
-positive switched air horn
-negitive switched air horn
-electronic air horn
-direct compressor drive air horn
-stored preassure air horn
not to mention relays and what you are using for switch, or what vehicle it goes into.
Yotatech is a great place if you can formulate a complete question.
Hella airhorns are positively switched, direct drive air horns. You should just be able to tap into the wire that goes into a stock horn run it to the compressor and then ground it anywhere. Then cut the other stock horns wire so you don't blow fuses and sound lame.
Lamm
Old Dec 19, 2005 | 09:52 AM
i_rifiyou's Avatar
Old Dec 19, 2005 | 03:59 PM
4x4Lamm's Avatar
You are welcome.
Lamm
Old Dec 25, 2005 | 08:39 AM
Larry77's Avatar
I've been thinking about getting that air horn also...how does it sound???
There are times when the stock horn just doesn't get the point across if you know what I mean...
91toybeater
Dec 27, 2015 07:46 PM
5280jo
10
Jul 13, 2015 10:05 PM
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
