General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Air horn wiring ...ack frack etc
Old 08-10-2008, 09:41 AM
Squiddy's Avatar
Finished installing a Wolo air horn system today. Basically completely along lines of tech article here: https://www.yotatech.com/forums/f127...4runner-75281/ ---- piggybacked wire to compressor into the horn wire (at the horn) (this is on my 1992 Pickup). No relay as don't really need...
While the regular horn still works as it's supposed to when ignition is off, now when I turn ignition, both horns (I think) instantly start blasting. I know that there is some weird ground/off thing for the horns on some rigs (as mentioned in prior forums) but I is veeerrryy confused on dis simple topic.
HEP ME HEP ME
Thanks!
Old 08-10-2008, 04:10 PM
Elton's Avatar
rip it all out and start over and use a relay and good 12-14ga wire
Old 08-10-2008, 04:33 PM
CJM
CJM's Avatar
Rip it off, wire it properly, you shorted it.
Old 08-12-2008, 04:41 AM
Squiddy's Avatar
Oy, everone's a critic...and none too helpful, to boot.
Well, doofus that I am, I still figured it out: Since the current was obviously going through whenever ignition on, that meant that either a short somewhere, OR that the presumptive ground actually wasn't, and current was running through the system "backwards" when power on. Latter turned out to be the case -- what appeared to be a black ground wire (which I piggy'd onto) wasn't. So, rewired proper ground and now works like a charm.
Friggin' loud horn, BTW
smthwsn357
05-01-2024 07:28 AM
MO transplant
04-23-2023 11:58 AM
the1998sr5
15
07-14-2020 08:35 PM
Doug4320
03-24-2018 10:11 PM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: Air horn wiring ...ack frack etc
