Aftermarket alarm kill switch problem, reset ECU?
Let me preface by saying this is not an OEM factory keyless entry, but a compustar (I don't know which model it is, and I can't tell from the remote).
I accidently let my battery die one day and found out that the car had a killswitch on it, so even when I charged the battery, the car still wouldn't start. I pulled the fuse for the alarm, however when I plug the fuse back in, the killswitch is still activated.
If I unplug the battery, with the alarm fuse plugged in, will this rid me of this problem? Thanks for any help!
There is no way to "reset" the alarm by simply unplugging. However, there is a way to disable it. That would be covered in the alarm owners manual. Assumably you no longer have that so you would have to go online and search around to find the way to bypass it. I had an alarm in my old 4Runner and the control box went tits up, so I had to bypass it. Usually they have a small button or switch to depress while turning the ignition to accessory or something. Every alarm is different.
Or, just yard that worthless junk out of there. Those kill switch alarms are problematic and not worth the time to mess with them.
Again, pulling the fuse does NOT fix it. In fact, it merely makes your truck completely disabled. When those alarms are installed, they rely on a start circuit interrupt, usually by cutting the ignition switch wire and splicing in the alarm/ignition interrupt.
Either yard the system out, or get the owners manual for the system and figure out how to reprogram or disable it.
Suprarossa
Jul 6, 2015 05:21 AM
