General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
99 4runner fog lights not working...
Old May 2, 2006 | 08:53 AM
Tikal769's Avatar
I installed new bulbs in my foglights about 4 months ago, all has been working great til last week. I notice my foglight were not on anymore even though the switch was on.
I replaced the fog light relay but that did not solve anything. Where else should I be looking? The relay clicks like it should when the light switch is turned on.
Could both new bulbs go bad at the same time? Any help is much appreciated.
Old May 2, 2006 | 09:10 AM
GSGALLANT's Avatar
Check the fuses. Did you put in the correct wattage bulb? Higher wattage bulbs could blow your fuses. If the fuses are OK, check to make sure that you have power at the fuses when the switch is turned on and the relay is energized. If you do, then check to see if you have power at the connectors right at the fog light. If you do, then try a new bulb.
PS. Instead of replacing the relay, you could have tested it quite easily. Not a big deal for a cheap part like that, but anything that can be checked should be checked before replacing - just my opinion.
Old Jul 17, 2011 | 11:45 AM
gotalite03's Avatar
I have the same problem with my 2003 tundra. replaced original lamps with silverstars
they worked very well for 2 months last week both went out at the same time.
the fuses are good not sure about the relays. I do have an ohm meter what should I check?
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
