General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 Toyota Pickup 4x4 22R Hazard problems
Old Aug 3, 2015 | 07:35 PM
jimkoz26's Avatar
I can not get the Hazards to work again. I have checked the HAZ-HORN fuse and is OK. I purchased a new flasher and no HELP. Check continuity on Hazard Switch and it was bad so I went junk yard hunting and found one and it checks ok. Still no Hazards. The horn does work.
Any Ideas?
Thanks
Old Aug 4, 2015 | 11:41 PM
wyoming9's Avatar
Red face
The turn signals work Fine ?? All the bulbs are good ??
the circuit to the hazard switch and turn signal switch must be open if the voltage is getting to the switch
As the hazards work through the turn signal switch perhaps the problem is in that switch.
Time to get some voltage readings.
Remember a single strand of wire will give you continuity or a very marginal contact on a switch but not be enough to carry the load.
Old Aug 5, 2015 | 06:12 AM
Terrys87's Avatar
^^^ A lesson I learned the hard way.
Do your blinkers work? The bulb holders can get really corroded.
Old Aug 5, 2015 | 03:15 PM
jimkoz26's Avatar
I replaced the switch with the one I picked up at the junk yard and no help. Everything works except the HAZARDS. I will do some more digging around this weekend.
Thanks for the ideas.
Crazychris1871
Jun 27, 2016 10:38 AM
Aleeex_u
Jun 5, 2016 06:52 PM
GorgeRunner
Jun 27, 2015 07:01 AM
bprice0077
Jun 25, 2015 07:36 AM
paxanders
Jun 21, 2015 06:29 AM
