85 head light on a 90
Is it the same housing size? Are they both sealed beam
Or is one just a housing with a replaceable bulb? If it fits in the same spot and plugs up it should work. If its not
A sealed beam from the 90 I'd replace both sides for equal lighting.
you're calling it a housing, which is making it a little confusing. the later 90s trucks had headlight capsules, which HOUSED a small halogen bulb inside.
so unless someone has done some changes to the configuration of either truck, they should both have H6054 sealed beams. if one's halogen and one's not, you'll notice the difference, but they'll still work.
they also cost like $5
ashersullivan88yota
Jan 18, 2022 05:37 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
