General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 electrical puzzle
Old Jul 4, 2017 | 01:31 PM
fishdan's Avatar
My 85 PU today while driving had the CHARGE light come on and the fuel gauge stopped working. Wipers and turn signals stopped working. Headlights and heater blower fan still working. NO fuses blown under the dash or under the hood at the fusable link. Motor still starts OK. Battery seems to be charging.
Grateful for any ideas. Thinking a short somewhere?
Thanks.
Dan
Old Jul 4, 2017 | 06:21 PM
fishdan's Avatar
Appears battery may not be charging. 12.4 volts at battery with truck running and not running.
Old Jul 4, 2017 | 11:23 PM
wyoming9's Avatar
Red face
Charging system not working .
Could be a wiring problem
loose fuse in the block I would look at `the 15 amp engine fuse again
poor ground
alternator itself
Old Jul 5, 2017 | 06:11 AM
fishdan's Avatar
Thanks!
Will take a look today.
Old Jul 5, 2017 | 11:13 AM
RAD4Runner's Avatar
Yes. Here's how to check charging system:
https://www.yotatech.com/forums/f199...l#post52094780
HOWEVER, most likely this...
Could be a wiring problem... loose fuse in the block I would look at `the 15 amp engine fuse again
15Amp engine fuse supplies alternator and turn signals. Without IG voltage, alternator will not work.
alternator itself
Less likely.
Old Jul 5, 2017 | 05:38 PM
fishdan's Avatar
Wink
The engine fuse had a hairline crack at the bottom corner. I had missed it. A new fuse and all systems back to normal!
THANK YOU! I could give you guys a big kiss! I would have been forever figuring that one out.
Old Jul 5, 2017 | 06:12 PM
RAD4Runner's Avatar
Originally Posted by fishdan
the engine fuse had a hairline crack at the bottom corner. I had missed it. A new fuse and all systems back to normal!
Thank you! I could give you guys a big kiss! I would have been forever figuring that one out.
cool!
Group-hug!
