General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
2018 Factory Battery already Bad?
Old Jan 12, 2021 | 05:56 AM
Tacotex's Avatar
Hey guys,
I recently started using a battery diag tool, and am deciding if a battery replacement is needed in my '18 SR5 4x4 Tundra. Even in a hot environment, I've always gotten 5-7 years out of a factory Toyota battery, but according to my diag tool, the factory battery already needs replacement. It was tested, then charged with a 5 stage desulfating charging. Whether or not it tested as "good battery-recharge", or "replace", depended on whether I selected "before charge", or "after charge". So, I waited a couple of days for the charge to settle, and tested again this am at the overnight low temp of ~32 degrees. The results are in the pic below. The truck seems to start fine, as it always has. I may be worth mentioning that I have also tested and topped up several lead acid batteries, with otherwise predictable results (one other lead acid battery, stored for years, was bad as expected, 3 others tested OK). I'm not one to wait until failure to replace something like a battery. What say you, and which replacement would you choose today (and why).
Old Jan 12, 2021 | 06:35 AM
Tacotex's Avatar
BTW, selections on the tool were:
In vehicle
Regular flooded
Before charge
710 CCA
The battery is made by Johnson Control, USA
Start and charge tests were "normal".
Old Jan 12, 2021 | 10:49 AM
2ToyGuy's Avatar
Personally, and I've heard in this forum that they're not what they once were, I prefer to use Optima batteries. The "gel-cell".
I've always gotten many years out of each one. Strong starts, down to around 0° F, even after several years of use. Best in my mind is that they don't corrode the terminals and wires that are on them with leaked acid, like a regular lead-acid battery does.
Just my personal preference.
Pat☺
Old Jan 12, 2021 | 12:30 PM
millball's Avatar
delete
Old Jan 12, 2021 | 05:27 PM
muddpigg's Avatar
Electronics on newer vehicles will reek havoc on a battery if lots of short trips with lots of electrical things on.
but shoot it’ll reek havoc on older rigs batteries too.
Buddy had similar complaint as you with his newer tundra.
Old Jan 13, 2021 | 07:29 AM
Tacotex's Avatar
Wound up replacing with $325 Odyssey "performance" AGM, after learning that Wal-Mart (Everstart Maxx) does not carry the 27F size for the Tundra. Used to be a Optima guy, until Johnson Control moved production from USA to Mexico, and ditched the quality Optima batteries once had.
silvercobra
May 5, 2013 04:44 PM
fightman80
Mar 18, 2011 05:19 AM
Rishi
Nov 20, 2005 03:07 PM
jtmaxx7
16
Jan 13, 2005 09:03 AM
