General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
2005 Sienna Rear Sliding Door
Old Dec 2, 2007 | 09:08 AM
lilredwagon's Avatar
The right rear sliding door on my 2005 Sienna XLE will open with the switches and the remote but will only close manually. What's up and how can I fix it?
Old Dec 2, 2007 | 09:51 PM
rowdy235's Avatar
by manually do you mean literally pulling the door, or just using the switch (handle) on the door, and it closes on its own.
Old Dec 2, 2007 | 09:55 PM
CJM's Avatar
CJM
Its a common problem, any mechanic can correct it but I think that toyota has a recall on them.
Old Dec 3, 2007 | 03:46 PM
trd90toyota's Avatar
What you will need to do is...
1. Lock the sliding doors with the button on the dash Do not use the door lock button on the door.
2. Disconnect the negative terminal end.
3. After about 30 sec, reattach the negative terminal end.
4. Turn the veh to on, DO NOT START THE VEH
5. Push the unlock button the sliding door from part 1.
6. Open the sliding doors at the same time 3 times. Let the door open and close fully three time.
7. Start the veh and the door ECU has been reset.
Hope this will help...
There is no recall on the doors, there is a TSB for the sliding door locks rattling and they updated the warranty for the front door checks breaking.
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
coleypull15
Nov 3, 2015 07:41 AM
icentropy
Jul 14, 2015 10:23 AM
cyclist231
Jul 7, 2015 12:56 PM
