General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
2003 4runner ABS/VSC lights on, can't shift into gear.....
Old Dec 15, 2007 | 07:08 PM
Ryan32's Avatar
I was installing LED map/dome lights and burnt the fuse for em, went and swapped that and my lights are back, but now my VSC/ABS lights are on, and the truck won't shift into gear it's locked out....
Any ideas? I checked every small fuse i have, none are blown, the only ones i don't know how to check are those big square ones, i can't even figure out how to pull them out.....
Old Dec 15, 2007 | 08:37 PM
rowdy235's Avatar
dang, thats a tough one. Keep in mind I own an 82 and warning lights are something I am not used to.
Try Pulling the - battery cable for around 5 minutes. Reconnect it and see if the lights are off. I think that will reset the computer.
Old Dec 15, 2007 | 08:53 PM
Ryan32's Avatar
no change.... left it for like 20 minutes.
Old Dec 16, 2007 | 10:45 AM
GSGALLANT's Avatar
I don't have my FSM with me, but isn't the shift lever locking mechanism released when the brake is pressed? Do your brake lights work when you press the pedal? If not, start there. Get the codes pulled to see if that will tell you anything.
Charecter1
Nov 6, 2023 10:08 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Jnkml
Jul 6, 2015 01:20 PM
