General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
2002 Highlander ECU
Old Jul 15, 2013 | 07:09 AM
Jason74's Avatar
2002 Highlander ECU
Hello,
My 2002 Highlander is in the shop for a valve job. One burnt valve and one bent in the same cylinder. The engine is back together and runs on all cylinders again, BUT, I'm told it needs a new ECU.
My mechanic said it is in "limp home mode". He believes the problem is a bad ECU not responding to two of the O2 sensors. He ruled out the sensors themselves by plugging in a known good O2 sensor and saw no response.
My questions.
1. Is swapping out ECUs a simple task, or do you need the keys from the donor vehicle, etc? He said there is theft prevention enabled that may make things not so simple.
2. Does what I described make sense?
-Jason
Naween Zohab
Nov 10, 2015 03:56 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
Boomer8404
Sep 24, 2015 01:12 PM
zz_denis
Sep 6, 2015 03:43 PM
