General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
2000 tacoma running on 3 cylinders?
Old Sep 8, 2011 | 01:39 PM
rayspang's Avatar
My perfectly great 2.7 tacoma started cutting out and ruuning rough. the check engine light would start flashing and then go off. it ran ok for just a little while, then started doing it again. I thought it would be one of the coils, but my mechanic says they are ok? He replaced a couple of spark plugs but tells me its still running bad. Compression checked out ok. anyone got any ideas??
Old Sep 8, 2011 | 01:48 PM
BMcEL's Avatar
If the compression is good it's likely a spark issue. Have you checked the resistance of the wires?
Old Sep 8, 2011 | 06:00 PM
rayspang's Avatar
Tacoma running on 3 cylinders
I'll have the mechanic check the wires. Could there be any sensors that could cause this ?
Old Sep 10, 2011 | 02:10 PM
rayspang's Avatar
After further checking it was a plug wire issue. One of the long plastic boots that attatches to the plug had a crack and was firing sporadically/horizontally to the block. Thanks for your help.
mskalmus
May 28, 2017 07:51 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
