General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1980 sr5 tach issues
Old Mar 30, 2024 | 06:52 PM
Tuga9037's Avatar
Hey guys I have a 1980 Totoya pickup dlx. I bought a sr5 cluster from a junk yard to swap into my truck. When ignition is turned on the tach jumps up to 2.5k and stays there whether running or not. I wired up signal from the ignitor where you are supposed to grab signal and pinned it into the correct pin on the cluster but no difference. So I dove into the cluster to see if anything was wrong and found a burnt resistor on the circuit board, as seen in the pictures. If anyone has a picture of the board on their tach I need to see what band color pattern the resistor is (or the resistor value) so I can solder in a new one. Thank you!
You can see the burnt resistor onbetween the green and blue capacitors
Old Jun 2, 2024 | 12:31 AM
sodkil's Avatar
i wish you made this 2 weeks ago when i was fixing my ae92 tach to work with a megasquirt.
192.168.100.1 192.168.1.1
Tuga9037
Apr 23, 2024 02:23 PM
Ztank
Nov 19, 2013 07:05 PM
MCMLXIX
Jul 24, 2012 09:45 PM
87redyota
Jul 17, 2011 06:13 PM
vwfastg60
Nov 5, 2007 11:56 PM
