Maintenance & Repair Care and feeding of your rig
Finewire plugs
Old Jan 12, 2010 | 02:45 PM
zach@sparkplugs.com's Avatar
Finewire plugs
Hope I did this right, if I need to change anything let me know!
Thought I'd post a quick article on finewire plugs for a little interesting reading.
Fine wire center electrodes come under a variety of names depending on manufacturer, IE - Tapered point, Ultra-Fine electrode, Taper cut electrode, Necked down electrode). Originally designed to improve starting and reduce fouling in two-stroke engines, this design was found to improve performance in four-stroke engines as well.
All operate on primarily the same principle, a spark plug with a fine wire electrode will perform better than a traditional plug. There are two reasons for this, first is because a smaller center electrode requires less voltage to jump the gap. This means fewer misfires, which should be seen in higher mileage and more horsepower. The second reason is smaller center electrodes reduce quenching. The smaller center electrodes require exotic metals such as platinum or iridium so that they can still maintain (and usually surpass) the longevity of a traditional spark plug.
Currently the finest wire performance plugs available are made by Denso at 0.4mm diameter (image 1), by NGK at 0.7mm diameter (image 2), and by Champion at 1.1mm (image 3), a traditional center electrode is typically 2.0 to 2.5mm (image 4).
The latest advancement in finewire plugs has been the NGK double fine electrode plug (image 5)
Image 1
Image 2
Image 3
Image 4
Image 5
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
