Ford horn in 87 pick-up
First remove the grill to get to the stock horn. it should be on the passenger side.
I used a piece of back strap i had laying around. Any strip of metal should work. I had to drill bigger holes in it to mount the horns.
Find a place to mount them so that they don't hit anything. I had to tweak it just a bit so that it wouldn't hit the grill.
I used these crimp on connectors so i didn't have to cut the stock plug off. The blue was + and the green was -
You have to wire up a relay. The ford horn grounds to the frame, if you mount these to the frame and hook up the + the horn will stay on. I wired my relay like this.
86 ground on the stock harness (the green wire)
85&87 positive on the stock harness ( the blue wire)
30 positive on the horn itself
Hope this helps someone get rid of their stock dinky horn. Here is it all finished.
LittleUgly
15
Jan 2, 2020 01:30 PM
kbpickens
Oct 2, 2015 03:37 PM
Toys4parts
Sep 26, 2015 01:56 PM
