Alarm Systems Discussion related to installation, diagnostics, and purchasing of alarm systems
recommend me a keyless/alarm system
Old Aug 25, 2011 | 08:31 AM
jeetS's Avatar
Anyone have tips or preferences?
I have power lock, and would like keyless entry...that's basically it, though a basic alarm would be handy...nothing super complicated or fancy
Recommend away!
Old Aug 25, 2011 | 10:32 AM
meisentones's Avatar
Keyless Entry, not complicated or fancy, hmmm....
Old Aug 25, 2011 | 10:53 AM
BigBluePile's Avatar
Viper.
Old Aug 25, 2011 | 10:57 AM
ChefYota4x4's Avatar
I'm about to get a Viper,...... This Alarm/Stereo Guru of 30 years that I know.... he called me and said, "there's a new Viper out with a GREAT engine kill system.... c'mon down when yer ready"... (I'd been asking him to tell me when new stuff comes out). He's going to set up some special stuff due to my 4runner/top comes off, and give me the rear window roll down feature as well.) He's someone I somewhat know, personally, so 279$ installed.>> Door Locks, engine Kill, Shock/window/door handle sensors, plus a couple SECRET THINGS! LOL.
Old Aug 25, 2011 | 11:48 AM
jeetS's Avatar
All I'd want is a keyless fob...anything else is bonus untill it gets too crazy (ie proximity, vibration etc...)
Old Aug 25, 2011 | 11:51 AM
scuba's Avatar
Viper.
Old Aug 27, 2011 | 12:09 PM
drpdmazda's Avatar
$46 shipped, viper basic keyless entry:
http://www.ebay.com/itm/VIPER-412V-K...item53e8ddde66
you looking to install it yourself or have a shop do it? most places sell them with labor included, but installing it yourself would be pretty easy. can get power from the ignition harness and hte door lock wires should be right in the drivers side kick panel.
Old Nov 8, 2011 | 06:25 PM
sctrep's Avatar
I'm going with a RFID access control unit. Just put the key ring near the "pick up point" and the unit will unlock doors , lock doors, start car, ect. whatever you feel like wiring to it. Im just gonna go with door locks for now. Here is a video of what Im talking about.
http://www.youtube.com/watch?v=mpwHLdCsMEQ
Old Nov 9, 2011 | 09:30 AM
Soooooo, ..... a chip installed in my hand? GOOD LORD! lol. Each to his own... not EVEN going to get me on the table for that one, hahaha...But I admire his commitment/level of dedication to his products/ideas.(Makes me think of a Movie or two where they take the persons hand OFF and place it on the scanner? lol)... BUT, the card key entrance/start is GREAT!
I heard of Password entry, where you use your phone and enter a 16 letter/number code? Crazy stuff out there already, ya know? Could call "Atmanan/Gregory" like in 'Horrible Bosses' and have him start the car for ya, too, eh? hahaha.
Old Nov 9, 2011 | 01:48 PM
sctrep's Avatar
You dont have to have the chip!!! I wouldnt do that myself. LOL
the kit im looking at comes with a key chain that "activates" it.
here is the kit: only $22 on this guys Ebay store.
http://www.ebay.com/itm/160493201114...84.m1438.l2649
Old Nov 24, 2011 | 02:27 PM
93NMyota's Avatar
Autopage RF-225a, I install these units on a daily basis, will work as a keyless entry or programable as an alarm just gotta hook up the door trigger wire, it has a shock sensor built in and it can be adjusted or disabled without lowering the dash. The fobs are also heavy duty
Old May 14, 2013 | 04:55 AM
JSchumada's Avatar
Python 513...!
Old May 31, 2013 | 11:36 AM
nashulee's Avatar
Here is the straight up skinny.... Viper, Python, Clifford, Avitol, Express and a few others are all owned by the same company. All of them are Directed Electronics products. The boards and internals are virtually all made the same. They are all a quality product of and in themselves.
The true difference in a quality alarm and one that does not work rests 90% on the installation.
How well it works: Does it pick up all the points of entry? Does it respond well at a good distance? Does it work every time? Will it last? All of these questions are directly to related to the actual installation. Did the installer solder all the connections ore use but connectors or did they T-tap? Did the installer garb the wires and info it needs in the right spot or did they get lazy and go for the easiest spot, which sometimes is not the same things. It can make a difference where you pick up ignition source, constant power and door triggers. For example, many many systems have the ability to sense voltage sensing. They monitor the main power input that is connected up and if there is a change ion voltage, it will trigger the alarm. Many installers will use this as the way to trigger the system if the door is opened. This is not a good way to get that trigger and will inevitably cause false alarms. Another is example is using T-taps. very common in the budget alarm install. the t tap will work for a short while but again, inevitably will cause issues. Consider that a car is constantly vibrating and shifting and hot and cold and hot and VERY hot and Very cold and vibrating. It is a rough environment. The best method in my opinion is always going to be good tape and solder. A good quality electrical tape will work amazing. Also Solder and heat shrink, though on the larger wires that are connected to like the ignition, etc, cutting those wires in half and then re soldering can be tricky.
the next important thing is prepping the alarm. A good alarm install, half the time is spent getting the alarm ready to go into the vehicle itself. When I install, I know where the connections are going to be and tape all the wires up in black tape all together so they are running together to the same location. This is how the factory does it, this is how I would do it. It makes for a little longer install, but it makes for a cleaner install. I figure out all the wires running to the kick panel and send them all there. I also run all extra wires not being used to the kick panel, so that in the future, if I need to do something with those inputs and out puts, they are accessible. That leads me to the last thing. Cleanliness of the install. When you look up under the dash, you should not be able to tell what wires were from the factory and what wires were from the alarm. It should all look the same. It should all be taped the same and the brain hidden. No jumble of wires pointing directly t the brain and an easy easy easy bypass.
Where do I draw my opinion? I did this for a living for over 10 years. Started out working at Dalworth CB and Car Stereo, then moved to a shop called Autotronix Custom Car Audio and then to DFW car Stereo. I loved doing alarms, they were my specialty and in every alarm I did, I would try to do the next one better than the last. I would take pride in the work I did. With an alarm, I can do virtually anything that the cars did on its own electronically. Start it , stop it, roll the windows up and down, pop trunks, remote winch, put tops up and down, turn neon on and off, remotely move amp racks. With a re'ay or two or 5 it can be done!!!
So this is my first post here, and you can take it for what it is worth. But I believe ask any good installer and they will tell you the same thing.
39 Thieves
Jan 6, 2017 01:08 PM
shisha1999
Sep 20, 2015 11:44 AM
skeeter0288
Aug 16, 2015 09:40 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
TJWilly
Jul 31, 2015 02:05 PM
