wud you wrench on this past weekend?
Old May 31, 2006 | 06:09 AM
MudMonkey's Avatar
Changed spark plugs, wires, and shocks on my wifes Mountaineer. Changed the plugs and plug wires on my Taco.
Old May 31, 2006 | 08:07 AM
SlightlyModified's Avatar
welded the motor mounts, and mounted the motor in my 81. Changed oil, and diff fluid in my atv. Patched my wifes tire on her car.
Old May 31, 2006 | 08:36 AM
linuxrunner's Avatar
replaced my starter contacts.
Old May 31, 2006 | 08:50 AM
seaflea's Avatar
Replaced a bad battery cable and miscellaneous things on a 59 Austin Healey.
Old May 31, 2006 | 09:19 AM
  #25
L33T35T 4Runner's Avatar
Finnished hooking up onboard air system, which i will be showing everybody soon
10 gallon tank, dual compressors, isolated battery, homegrown 4air system, it's a beauty
Old Jun 21, 2006 | 08:49 PM
  #26
boogyman's Avatar
woo! you can air me up when we leave pismo in august
Russell
Old Jun 21, 2006 | 09:17 PM
  #27
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
added aux. fuse box, replaced cb
Old Jun 21, 2006 | 09:56 PM
  #28
Ringmaster's Avatar
Clutch disc, Pressure plate, Throwout brg. Pilot bearing, and tossed the stock clutch pedal return spring in favor of a more normal spring, which is quiet, compared to the squeaky O.E.M. setup.
Old Jun 21, 2006 | 11:52 PM
  #29
rocket's Avatar
Rebuilt and rewired a couple harnesses/plugs to connect JDM headlights to USDM wiring on my '93 Integra...turned out nice.
Old Jun 22, 2006 | 06:18 AM
  #30
snap-on's Avatar
I put a roof on my grandma's house.
this weekend its a roof on my garage.
Old Jun 22, 2006 | 09:03 AM
  #31
Tragic Drive's Avatar
Installed a 170 degree thermostat yesterday. It was a Napa brand and it didnt have the jiggle valve like the factory one. I road tested it and havnt had any problems.
Old Jun 22, 2006 | 09:42 PM
  #32
frankjake's Avatar
Didn't work on anything, went on a 250 mile trail trip. Had a great time, nothing extreme, but fun non the less.
Soon to come will be replacing the front speakers, they are blown. The rear (stock) still sound okay, at least for an off road vehicle.
Old Jun 26, 2006 | 07:11 AM
  #33
Ringmaster's Avatar
99 4Runner 3.4 6
Timing belt, Water pump, both Idlers, fresh antifreeze/coolant.
4 1/2 hrs. start to finish..
Old Jun 26, 2006 | 07:21 AM
  #34
DavidA's Avatar
Got new tires on the rear and did the full time power outlet mod, not sure I like it yet because I left the radar detector on all night.
Old Jun 26, 2006 | 07:28 AM
  #35
da_bigg_wigg's Avatar
Removed the uggo running boards...
Old Jun 26, 2006 | 07:42 AM
  #36
gregbreakseverything's Avatar
Switched engine oil, front/rear diff oil, and transfer case oil to synthetic. Props to Bob and his sweet writeup. Nomore wondering what bolts to take out.
Old Jun 26, 2006 | 09:14 AM
  #37
86SR522REEFI's Avatar
Changed oil, Replaced slave cylinder for the second time in 6 months, Took my tools to toyota. Then I warshed her. But then had to get it dirty again.
Old Jun 26, 2006 | 09:28 AM
  #38
snap-on's Avatar
i put the roof on sat... sunday i was so beat the only thing i mannaged was to run some erronds and yard work
oil changes tonight for both bimmers.
and ive GOT to budget some time to clean up in the garage!
Old Jun 26, 2006 | 10:15 AM
  #39
Sherpa's Avatar
What did I wrench on this weekend? My back! I injured it again a few weeks ago and on Friday night I did something else to it. I spend all day Saturday and Sunday in a lot of pain whenever I tried to stand or walk.
Old Jun 26, 2006 | 10:16 AM
  #40
frankjake's Avatar
You guys seem to be working way to much.
We went for another long trail ride this past weekend, even pulled out a motor home that was stuck on a rock. A Snatch strap is a much have!
This week I will get the truck all cleaned up and ready for next weekend.
