Wrecked my Truck (photos)
Old Jan 4, 2006 | 10:52 PM
ChickenLover's Avatar
Originally Posted by viperdan
Looking around for parts I think i can get a radiator from pick-n-pull for around 40-60 or new for 90 on ebay.
There is an auto wrecker down by the airport that has a lot of toyota stuff (I think they might even specialize in toyota). I've only been there once, but I'm pretty sure it's called airport autowrecking (on Gentry way).
Old Jan 4, 2006 | 10:54 PM
viperdan's Avatar
Awesome advice, I'll check it out. I went down to the mustang station and they had a couple of our gen runners (one was a 22RE). Also, incase your interested, they had a 3vze with an sr5 gauge cluster (if you don't have one already).
Old Jan 4, 2006 | 11:14 PM
marko3xl3's Avatar
Thanks for the support! How bad was your rig?
Mostly cosmetical, but one corner had some supports smashed in, no frame damage. It was expensive to get back to normal, but it could be done. The only damage you see now is the "scar" of where the support was smashed, other than that, they shop was able to align all other parts and make it look like new!
Old Jan 6, 2006 | 09:45 PM
viperdan's Avatar
Updated Photos
Heres some new photos with the hood, grill, bumper, etc off...
Check out that crossmember!
Heres a close up of the frame damage on the drivers side behind the tire...
My friend and I pulled the radiator (which had a perfect imprint of the fan on its bacl) and bent the front back to make room for a new one, replaced the fan, there are some cracked hoses and a dented pulley. It doesn't look nearly as bad without the trashed tin. It runs fine! The steering is working fine, but the whole front end is slightly shifted to the drivers side. Hopefully the shop will be able to straighten it.
Old Jan 6, 2006 | 11:39 PM
  #25
JMT529's Avatar
I might be interested in the Duelers. What size are they and how much are you looking for them? Thanks.
Old Jan 7, 2006 | 06:48 AM
  #26
viperdan's Avatar
I actually can't part with the duelers yet, due to a bent wheel, I need to put those on to limp to the frame shop. Maby after that though... I think they are 29x9.5 or 30x9.5 can't remember (they came with the truck)
Old Jan 7, 2006 | 07:51 AM
  #27
JMT529's Avatar
No problem. Do you have a timeframe of when you might be able to sell them? And how much you are looking for? Thanks.
Old Jan 7, 2006 | 01:13 PM
  #28
viperdan's Avatar
I'm thinking probably around a month (when I can afford some new wheels). One of them has a patch so unmounted i'd let em go for about 150 for 4 of em.
Old Jan 11, 2006 | 07:41 AM
  #29
dougtrd's Avatar
Well thanks for your suggestion. If anyone has any parts they need let me know. I just bought a new NWOR idler arm brace (not installed), I've got nearly new 32.11.50R15 Siped venture m/ts also have a set of dueler a/ts (not revo) that are maby 65-70% new. The shell has paint that is peeling but would work for any xtra cab in my gen. I also have some infinite kappa 4" componants I could sell. Just let me know.
Glad to hear there were no injuries and that you will most likely rebuild...BUT...if you dont I am in the market for a good 22RE motor complete...so if you change your mind PM me and we can discuss $$ and transport!!
Old Jan 11, 2006 | 05:31 PM
  #30
Dailydriver2's Avatar
Man, It always sux when your Yota gets wrecked. Good excuse to go to SAS.
I trashed the red 1988 on the left (avatar) while driving too fast, not paying attention and rolling off an embankment in the mountains. Hope your rebuild goes well.
Old Jan 11, 2006 | 06:26 PM
  #31
InternetRoadkill's Avatar
You may want to pull the frame out from under it. It will make life easier to work on it. Maybe find a frame from another yota that's been rolled.
MadMax48
Jul 3, 2015 08:26 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
Edionne13
Jun 21, 2015 11:37 PM
