Wreck with a 3" body lift
Old Jun 13, 2011 | 06:16 PM
  #41
GenXr's Avatar
Originally Posted by 4Crawler
It is certainly recommended to re-use the OEM body mount washers. They are specially designed for that job and not the kind of thing you'll find at the local hardware store:
- http://www.4crawler.com/4x4/ForSale/...ockBodyWashers
Below (L-R) is a standard USS stamped steel washer, a typical OEM body mount washer and a hardened SAE washer:
Not only is the OEM washer thicker and larger in diameter but it is also hardened and has a very tight close fitting bolt hole. ...
Fortunately for me I'm running a 4crawler BL reusing my OEM washers!
So over all, I think this thread has been pretty useful and brought up some good information about body lifts:
Use quality HW
re-use the OEM washers
Check/retighten bolts after installation
Use only as much BL as necessary
the number of body mounts matters
Usually we don't get this type of technical discussion on body lifts. It's usually more centered on installation techniques and fitment.
Hat Tip to wabbit for the post mortem forensics and others for good discussion points!
Old Jun 13, 2011 | 06:23 PM
  #42
waskillywabbit's Avatar
When we roll the 4Runner back over I'll pull the body mount plastic caps under the carpet and take a look at the washer up close. I'm guessing they are the washers that came with the kit.
:wabbit2:
Old Jun 13, 2011 | 07:47 PM
  #43
Yidihevitz's Avatar
:wabbit2:
I'm guessing that you're right. But the kits that I know of require the factory washer, for all the reasons 4crawler said.
Old Jun 13, 2011 | 08:10 PM
  #44
4Crawler's Avatar
Typically yes, but that "kit" appears to be otherwise. Blocks look like Performance Accessories or similar, but those guys don't make a 3rd gen kit. So likely someone bought a kit for another vehicle then picked up hardware to fit the vehicle. Could be they even got the lift blocks off another vehicle and did not even have the kit directions.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
