Who will get farther?
Old Oct 23, 2008 | 04:32 PM
Skinsfan6's Avatar
Going digging tomorrow night. Got a friend going with me in his Chevy. Who do you guys think will get farther? Read everything before making a decision.
92-94 Chevy 1500 - stock tbi 350, 3.73 gears, 39" boggers, OPEN diffs, and about 35 degrees of angle on the front CVs
My 87 4runner - swapped in 22RE Turbo, Stock 4.10s (just right), front and rear lockers, 33x12.5 Bighorns (22psi front and back) full tread, cranked t-bars, about 13" of ground clearance under the front A-arm crossmember, but the CVs hold up fine with the locker, and a VERY spirited driver/experienced mud bogger
Old Oct 23, 2008 | 07:06 PM
bigarms23's Avatar
your 4runner
Old Oct 23, 2008 | 07:11 PM
904_runner's Avatar
Id say yours too, helps you have lockers front and rear.
Old Oct 23, 2008 | 07:15 PM
algranger's Avatar
Depends on the depth of the ruts, if you get hi centered too bad your toast, if thats not an issue, i would say your runner for sure.
Old Oct 23, 2008 | 07:22 PM
Skinsfan6's Avatar
I don't think the ruts are all that deep. And I've never been there before so I don't know how soft or thick the stuff is. It shouldn't really effect me. But I'm thinking he'll have a hard time turning over 39s fast enough to keep them clean and biting.
Old Oct 23, 2008 | 08:08 PM
tc's Avatar
tc
All depends on the kind of mud ... generally, I would say the locked rig every time, but 39" Boggers could be a huge hurdle to over come with 33's.
Old Oct 23, 2008 | 08:37 PM
Jay351's Avatar
Dude. Im sure that chevy can bearly get out of its own way with stock friggen gears! Friggen redneck
Old Oct 23, 2008 | 09:03 PM
SpecialScottie's Avatar
Pretty much anything locked front and rear is going to outwheel an open
Old Oct 23, 2008 | 09:41 PM
turboboost's Avatar
Your truck.
Old Oct 24, 2008 | 09:13 AM
tc's Avatar
tc
You all have to remember, we're not talking 22RE power here ... the bigger the motor, the less relevant the gearing becomes. Also, the lower gears are going to provide more wheelspeed. The 2x spinup factor of the open diff MAY help also.
With mud, all bets are off - it ALL depends on what kind of mud they get.
Old Oct 24, 2008 | 09:32 AM
Skinsfan6's Avatar
Although he doesn't have a 22RE you'd still be surprised at the power loss even with a V8. I have a 92 F150 with a fuel injected 302 and I had TONS more power with the stock 235s than with 31s and 33s. I keep 33s on it now, and I refuse to go any bigger without regearing. I have 3.55 gears in that truck. Now he does have 3.73s, but he's also only tbi, and I think once you get past 35 inch tires you pretty much should regear, even with a 350. I mean 39s are a lot of tire, and 3.73s are nothing with a stock 350.
This same truck, with 36s on it, did not get as far as me in a pit a few months ago. I only had a rear locker then, and he hit it faster than me, but I still got a litle farther than him.
Old Oct 24, 2008 | 10:42 AM
TOYOTA 1's Avatar
put it this way, ruts, and mud depth are the name of the game. if you guys go in deep mud/ruts he will pwn you! tire size does matter in that situation. lockers don't do squat when all 4 tires are off the ground.
but if your just going on some muddy trails, not deep bogs! then your rig should out perform his.
Old Oct 24, 2008 | 10:48 AM
eighty5yota's Avatar
shoot some footy so we can see who wins..
i wouldnt be a toyota lover if i didnt put my money on the runner
Old Oct 24, 2008 | 12:40 PM
foot0069's Avatar
The last one moving.
Sorry couldn't help myself
Jim
Old Oct 24, 2008 | 03:01 PM
Jay351's Avatar
Yeah, but we are talking about a stock chevy 350. Not by anymeans that powerfull in stock form. Jumping from a 31-39" tire is big, even for a v8. I remember a local guy, driving an older f-350, his tires were HUGE, but his truck could bearly make it up an incline at low rpm/speed. It was hilarious
Old Oct 24, 2008 | 03:19 PM
Matt16's Avatar
4Runner.
Old Oct 24, 2008 | 03:46 PM
brooklee1000's Avatar
Depends who goes first on the same line. If he deepens the ruts before you get in there, then unfare advantage to him for tire size. But , the lockers f&r will likely push you further. Your rig is likely at least 1000lbs lighter too.
Lighter weight and Locked wins INHO.
Old Oct 24, 2008 | 07:30 PM
Skinsfan6's Avatar
Well I was pretty disappointed with the mud.They were pretty deep ruts and a slick bottom, and water covering them. Nothing really thick. I used first gear in 2 wheel drive the whole way through. I wasn't even going that fast. Just kinda blipped the throttle on the entrance of each hole and held it about about 3000rpm and ate through at a walking pace.
The Chevy guy put it in 4wd when he turned onto the powerline. Not sure why. But anyway, he needed it. He went through one set of ruts that were off camber to the passenger side a little, and he crawled through slowly with only his front and rear passenger side tires spinning. It was pretty funny.
Conclusion: I know that at least in 2wd I will continue to own him. And Im really willing to bet even in deeper stuff I would have him. Only in deeeeep ruts with a hard bottom do I think he would do better.
And unless we get some killer rain this winter there is nothing near me that is really challenging with both lockers in. I may bolt on a set of 235/75-15 Michelin street tires on and go have fun in some mud. A little more challenge-there's nothing like wheeling in what feels like a stock truck.
Old Oct 24, 2008 | 07:55 PM
ryantowry_81's Avatar
i wouldn't underestimate the power of 39" boggers and a v-8. i mean yeah you did better in the shallower stuff but i have seen a fullsize chevy with 38 TSL's and a good motor with 4.10's go way farther than my truck with 32x11.5 LTB's and lockers because in the real deep stuff the wheel spin and height makes a real difference even if they arent locked.
Old Oct 25, 2008 | 08:25 AM
tc's Avatar
tc
Amen brother
