Where to buy grade 8 bolts?
Old Feb 16, 2008 | 01:13 AM
Scooby098's Avatar
I know the construction store down here has them for cheap garretsons.
Old Feb 16, 2008 | 05:46 AM
waskillywabbit's Avatar
Originally Posted by Sosborne
I've checked all the sources on this post for the M12-1.25x30mm Grade 10.9. None of them have them. Does anyone know anywhere else to look? I can find this size in Grade 8. I didn't think that was strong enough though.
I even tried google and cant seem to come up with much
What is the application? A M12 x 1.25mm is very fine threads. If you are looking for an OEM replacement bolt try the dealership.
Old Feb 16, 2008 | 05:57 AM
RustBucket's Avatar
If you ever have the opportunity to drop your front third member out, you can also just drill out the holes to 1/2". Then the "studs" just become bolts. That's what I'm running on mine.
Old Feb 16, 2008 | 06:04 AM
mt_goat's Avatar
Just use the metric grade 8.8 if those metric grade 10.9 are too hard to find. I don't think Toyota uses any 10.9 bolts from the factory (maybe the head bolts or something).
Old Feb 16, 2008 | 06:19 AM
  #25
Sosborne's Avatar
Ok, I was just concerned that 8.8s wouldn't be strong enough for the brake caliper bolts. The ones I have on the truck now have the heads all knurled from the PO. I need to change them out. I've noticed that that most of the bolts Toyota used aren't that good. Living in the rust belt I have have to drill out many bolts on the undercarriage and hellicoil them. I try to replace the fastners with 10.9s as much as I can.
Old Feb 16, 2008 | 07:52 AM
  #26
tc's Avatar
tc
I order mine from Fastenal. Ace Hardware has a pretty good selection of coarse thread, but not so much in fine thread.
That same size is also used for the CV's, the crossmembers, and the diff-to-mount connection - it's good to have some spares!
Be sure to use anit-seize or loctite to keep the salt out of the threads!
smthwsn357
May 1, 2024 07:28 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
yoterr
Jul 24, 2015 04:29 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
