whats wrong with it?
Old Jul 22, 2007 | 11:16 AM
4x4yoda's Avatar
i was driving my truck and i was approaching a stop light. i down shifted to 2nd gear and the rear tires locked and skidded for a second. after stopping at the light i noticed my truck was not running. the started my truck and it stalled instantly. i started it again and as soon as i let off the gas it stalled again. i started it and stayed on the gas to keep it running.
i've adjusted the idle so i can continue to drive it but does anyone have any idea whats wrong with this thing?
Old Jul 22, 2007 | 12:20 PM
MudHippy's Avatar
Check your brake booster hose. It may be loose or cracked causing a vacuum leak. Makes you engine struggle to run at idle and your brakes not work right.
Old Jul 22, 2007 | 12:30 PM
4x4yoda's Avatar
brakes work fine.
Old Jul 22, 2007 | 12:35 PM
Bigblock's Avatar
What are you working on?
Old Jul 22, 2007 | 12:43 PM
tj884Rdlx's Avatar
when you downshift and drop the clutch too quickly, causing the rear wheels to chirp, you're doing a "compression lockup". i used to think this was fun to do with the company truck (a mazda b2000) when i was a stupid teenager. unfortunately its apparently a good way to blow a motor. could you get it running again at all?
if you're not a serious wrencher, get that thing checked out for broken t-chain to start, do a compression check, etc. good luck.
Old Jul 22, 2007 | 01:44 PM
MudHippy's Avatar
Originally Posted by 4x4yoda
brakes work fine.
You really wont notice the difference untill you fix the the vac leak. I was more thinking that because of the problem with your idle, so it's still a good thing to take a look at.
I've had the same EXACT thing happen to me(hard downshift), and the brake booster hose had backed off the fitting on the brake booster housing. I pushed it back down and that fixed that.
Old Jul 23, 2007 | 04:40 PM
4x4yoda's Avatar
the truck runs but its kinda rough. i'll drive it until i get my datsun running.
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
