What do you do before you start a critical change?
Old Jun 20, 2009 | 07:59 PM
ToyotaLandLady's Avatar
Am I confusing you will my ball joint puller bit?
That IS what this is, right?
Mind you this is not 'THE ' one in question, but it's what it looks like.
Old Jun 20, 2009 | 08:01 PM
Team420's Avatar
thats a jaw puller, idk id it strong enuf to do bj's
This is a ball joint puller,http://www.harborfreight.com/cpi/cta...temnumber=4065
but it's [pretty useless unless you pull the whole knuckle
Old Jun 20, 2009 | 08:03 PM
BigBluePile's Avatar
it's a three jaw puller, I used one for doing pulley's with but it should work.
This is what I use:
Ahhhh, hmmm.... unfortunately he's been drilling so long I bet hes heated the ball joint up and FUSED it to the underside.
What is the tool he should be using?
His looks almost exactly like this:
Old Jun 20, 2009 | 08:04 PM
  #25
less moving parts and prolly stronger...
  #26
This is what I use:
Gotcha!
I'm going to have to bring him in then.... I'm pretty sure we dont have one.
Old Jun 20, 2009 | 08:05 PM
  #27
A pitarm puller or tie rod end puller
Old Jun 20, 2009 | 08:07 PM
  #28
seanmearse's Avatar
jaw gear puller, watch out on the center bolt, as i have seen they have a tendency to strip under to much force. i think our store is on number 8 or9 for the tool rental.
  #29
Well, he got the first one out with it... it's this second one that is proving to be hard... everything is closed by now- thank goodness church isn't until noon!
I don't think we're going anywhere anytime soon.
Old Jun 20, 2009 | 08:08 PM
  #30
Team420's Avatar
A tierod pickle fork( not one for bj's its too wide), and a bfh, once the pickle fork is wedged in good, hit where the bj goes into the knuckle a couple times, it should pop out after a couple good smacks.
Old Jun 20, 2009 | 08:12 PM
  #31
soak with PB blaster? Then put on jaw puller, put on tension, SMACK with bfh, continue to tighten, SMACK...rinse, repeat. Should pop off easy! lol!
Old Jun 20, 2009 | 08:14 PM
  #32
Well... the issue is that he's been drilling the thing for 3 hours.
I think it probably no longer resembles a ball joint fellas. I could probably bet money on that, actually...
Old Jun 20, 2009 | 08:15 PM
  #33
seanmearse's Avatar
Grinder time!
Old Jun 20, 2009 | 08:16 PM
  #34
But you guys rock... soon I can go help him actually do this. At the moment I don't fit under the car, hahahaha- otherwise I would be there.
Old Jun 20, 2009 | 08:17 PM
  #35
seanmearse's Avatar
If you have a pickle fork large enough, bolt it back up and go to town on it with said bfh..
Old Jun 20, 2009 | 08:18 PM
  #36
Shoot it?
Old Jun 20, 2009 | 08:19 PM
  #37
seanmearse's Avatar
Grenade!!!
Old Jun 20, 2009 | 08:20 PM
  #38
He said he's boring the ball joint out, it's up in there on the tie rod apparently so he's just trying to bore it out.
Old Jun 20, 2009 | 08:23 PM
  #39
replace the left rear tire. Fixes it every time!
  #40
seanmearse's Avatar
That could take a while, thats some hard metal in there. give the PB a shot, soak it good, come back to it in an hour or so and soak it some more, then hit hard.
