Way to reduce gap on hi-lift jack mount?
Old Feb 11, 2016 | 04:05 PM
FinallyOffRoad's Avatar
Anyone know of a way I can keep my hi-lift jack from sliding back and forth in my roof rack mount? The mount is about 3" wider than the jack and the jack slides back and forth ask I drive. I was thinking of putting in rubber blocks, but I can't find anything like that.
I'm not sure if you can see in this picture, but the mounts are way wider than the jack bar.
Old Feb 12, 2016 | 03:02 AM
muddpigg's Avatar
Post up pics of just mounts.
Old Feb 12, 2016 | 04:25 AM
Old Feb 12, 2016 | 04:27 AM
donomite49's Avatar
I would look into wrapping a cable with a lock around it and the rack for security and the movement issue
Just looked at the mount pics, easy fix is to cut tubing for spacers
Old Feb 12, 2016 | 09:37 AM
muddpigg's Avatar
Some sort of bumper padding, tubing or rubber. Depending on area you live X2 on securing it. You may not stop a thief but "will help keep an honest man honest."
Old Feb 12, 2016 | 11:43 AM
highonpottery's Avatar
get a piece of redwood or HDPE plastic, the thickness of the gap, and simply drill a hole in it for the bolt to pass through. That should solve the movement, then I'd Plasti-dip the brackets themselves so they're isolated with rubber from making noise.
Old Feb 12, 2016 | 12:30 PM
wyoming9's Avatar
Red face
Just looking I could think of a dozen different ways to do that.
What were those brackets made for ??
Even pieces of Nylon or ABS plastic that most any industrial supplier stocks .
I buy things like that from McMaster -Carr because the Brown truck brings it.
Cheaper then I can drive and hunt for things.
Old Feb 12, 2016 | 06:28 PM
dropzone's Avatar
Fossilized
Cut those mounts off, use a half inch bolt, nuts and a wing nut.
You can get the idea from this mount I made for mine
I designed mine for tubing but the same idea could be applied to a rack mount
Old Feb 14, 2016 | 02:13 AM
combatcarl's Avatar
1" heavy duty hose, cut a piece 1-1 1/2" long, drill a hole across it, stuff it in there and run the bolt thru it. Replace every few years as needed.
StangBanger
Jul 23, 2018 06:36 AM
arlindsay1992
Nov 16, 2016 03:45 PM
Scotto6591
Feb 6, 2016 09:12 AM
4by4yoter
Feb 6, 2016 08:58 AM
