Washingtonians
Old Feb 7, 2009 | 07:40 PM
algranger's Avatar
Washingtonians
People of the evergreen state!
Anyone wanna lend me a bi-hexagon 12 pt. bit for a few days? I will give you $20 or beer whichever you want
I just ordered one and its a month out still and I have a Tercel i need to get rid of but it needs a head gasket first.
I'm in yelm, kinda sorta near Lacey
EDIT:
It's one of these
It's not your traditional one there is two kinds of 12 pt, i need the one on the right
Reason i ask is the only place i've found to get one has me on backorder for a month and i need it sooner
Old Feb 7, 2009 | 07:43 PM
BigBluePile's Avatar
How 'bout a skid plate?
What exactly do you need?
Old Feb 7, 2009 | 07:49 PM
algranger's Avatar
its a 12pt hex key i forgot to mention its 8mm
not like most though, its bi-hexagon not the standard kind
Old Feb 7, 2009 | 07:56 PM
12 sided? What does that go on the car?
Old Feb 7, 2009 | 07:59 PM
algranger's Avatar
Its the damn head bolt
Old Feb 7, 2009 | 08:06 PM
Hmmmmmm, a regular hex won't fit in there huh? Can you grind a notch in it and use a straight slot?
Old Feb 7, 2009 | 08:10 PM
algranger's Avatar
i'd rather not cause if it for some reason doesnt work, then i'm really screwed, i might try it tho...
Wow just saw your edit. Seriously, you can't use a regular hex. I hate star tip fasteners, we use them on jets now and they strip out quick.
Old Feb 7, 2009 | 08:12 PM
Are these countersunk?
algranger's Avatar
yeah theres hardly any contact area on there why not a regualr 6 sided male bolt
whhhyyyy toyota!?
Old Feb 7, 2009 | 08:14 PM
algranger's Avatar
yes
well it has a head on it the head has the female reciever
Old Feb 7, 2009 | 08:21 PM
yes
I'm trying to picture the bolt, is the outside knurled? Enough for a socket?
Old Feb 7, 2009 | 08:24 PM
algranger's Avatar
bolt looks just like this
and looky what i found!!!
Should be able to do that tomorrow i'll give it a shot!
Old Feb 7, 2009 | 08:29 PM
I'm not going to lie to you, that is one goofy ars bolt!!
They setup should work, just make sure to use a jam nut or weld it together.
Old Feb 7, 2009 | 08:32 PM
algranger's Avatar
i'll probly do both lol it's gonna be high torque. then i'm gonna go buy some real head bolts from napa
Old Feb 7, 2009 | 08:44 PM
It'd be a good idea, hate for you to bust a nut while doing those torque loads...
Old Feb 8, 2009 | 04:26 PM
Hey Al, how'd your homebrew tool work out on those headbolts??
Old Feb 8, 2009 | 05:03 PM
DeathCougar's Avatar
That design is what ALL toyota headbolts look like now. Not sure why toyota went with that particular bolt design, but it has something to do with the ability to hold better.
Old Feb 8, 2009 | 06:24 PM
algranger's Avatar
it didnt work, just snapped in half, it's actually such a small bolt (about an 8th inch diameter) i didnt expect it to work.
man this is pissing me off but i'll get something worked out
Old Feb 8, 2009 | 07:11 PM
How about welding the nut to something else? Like an old socket 6" extention?
