Warming up - Waste of gas or preventative maintenance?
Old Apr 15, 2010 | 05:12 AM
Fink's Avatar
Originally Posted by low-n-slo
i look at it like letting your car sit and idle is only warming up the engine, what about your diff fluid, transfer case and tranny. What i do is start it up, buckle, get the radio on and take off nice and easy. the first few shifts are very smooth and gentle and when i get to the first stop sign i ease the brakes to make sure they are working still. once i hit operating temp which takes like 5 min i start getting on it. Remember if its cold out all the gear lube in your truck is gonna be very thick like glue and settled to the bottom, the only way its gonna get loose and where it needs to be is by moving.
That's a very good point - I guess I should have said that even after letting the engine warm up I still take off very slowly and let the ECU figure out when to shift.
Here's another question that a quick Google search could probably answer for me but I'd rather see what you guys have to say (go ahead BAN me) - at what temp do most of those fluids become viscous enough to lubricate efficiently?
Say the temp outside is 80*, rig is partly in the sun but hasn't been driven for 3hrs...fluid temps are probably right at 80 or maybe a little above (depending on shade, etc...).
Warming them up for a few minutes while driving slowly will raise them to what? Maybe 90-100*?
At what point do they reach their maximum viscosity?
Fink
Old Apr 15, 2010 | 05:25 AM
low-n-slo's Avatar
i would guess in a short drive they would probably get up to the high 100's, their is a lot of pressure and very fast moving parts involved.
Old Apr 15, 2010 | 09:23 AM
Etype R's Avatar
I let mine warm up when its below freezing, so I don't freeze!
Summer time, I jump in and go.
Old Apr 15, 2010 | 12:57 PM
Jay351's Avatar
In the summer I let it idle for a few mins, usually a songs worth.
In the winter I let it idle till the fast idle drops down to 1100rpm.
Since the motor uses dissimilar metals I figured the best way to let them warm up and expand is at a slow controlled rate. In addition I never rev it past 3,000rpm till its nice and warm.
My truck doesnt like driving when its cold.
Old Apr 16, 2010 | 12:43 PM
  #25
surf4runner's Avatar
Originally Posted by vital22re
I always give it a min or two, just to get the juices flowing. Don't wanna pull a hamey
i wait for a few seconds (seat belt on time) always. longer when its cold out.
dont hammer it until at temp.
on my carbed cars, i defintely wait a few minutes if its hasnt run for a day or more.
on the same note i had a discussion w/a friend about a FI fuel pump.
do you let it pressurize before starting?
i never do. key in - vroooom!
Sleaker
Aug 26, 2020 06:03 AM
pyramid
Jul 30, 2015 10:05 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
daddio
Jul 18, 2015 10:20 AM
Kluch8651
Jul 9, 2015 10:39 AM
