Vibration problem, help please!
Old Jan 5, 2008 | 12:43 PM
ReturnoftheR's Avatar
Hey,
The truck in question is a 1997 Toyota Tacoma. 80K miles.
My problem is a vibration that occurs around 35mph and continues untill around 65-70mph. Even then it is off and on.
First I thought it was the universal joints, how can I tell that they are shot? I went under the truck and I cant tell what play should or shouldnt be there.
After doing some searching I wanted to check my differential. I jacked the truck up and moved the wheels. I was checking for abnormal noises, and i did hear a slight "smooth rubbing" noise, but nothing that sounded too bad. Should i have heard anything at all?
What should I check next?
Thanks for your help!,
Paul
Old Jan 5, 2008 | 01:24 PM
toytech76's Avatar
Take the driveshaft out and take it to a driveline shop to have the joints checked and the shaft balanced. Also check the trans case output flange for looseness. The nut sometimes will back off
Old Jan 5, 2008 | 05:48 PM
bigarms23's Avatar
sounds like you need to replace u-joints and have shafts rebalanced
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
