Turning rotors on your own
#41
I guess I must me out of my mind...... I have done what you claim is impossible.
I've always done my own wheel alignment, won't ever let a shop touch it, got over 40k out of my last set of MTR's to prove it......
PistonSlap, the next time I sand a disc, I'll have a few fellow Yotatech members come over to observe, I have micrometers and dial indicators to measure before/after results. Then I'll let them post the results, will this be enough to prove it can be done?
#43
Yeah Genius, that shows exactly how to adjust camber and caster. Quality post. Last time I checked you adjusted toe after you adjusted camber and caster. Not to mention that you can't eyeball .01" with you stanley tape measure. Yes you can get it close, but you are not going to get it 100% everytime. There is a reason that shops invest a lot of money into alignment equipment. If it was as easy as that, then they wouln't need extra equipment.
Shops invest money into expensive equipment so that they can hire anybody off the street and get them working with minimal training. For example, Mcdonalds. It doesn't take a "genius" to flip hamburgers, but they've still got tens or hundreds of thousands of dollars in hamburger making equipment.
It ain't rocket science. I aligned my solid axle myself and it's fine (granted, it's easier than ifs).
#44
As for a way to measure, I have all the proper equipment to do the job.
I have over 30 years of real world experience at wrenching and a certified master technician. If you don't believe me ask any of the local Yotatech member around that have come over to my place and seen me in action.
What experience do you have, to qualify yourself...other than the obvious?
#45
Apparently, not even the shops that use the equipment can get it 100% every time. Where do you keep getting this 0.01" number anyway? There's more slop in the steering and suspension than that.
No one off the street is going to be able to walk up to an alignment rack and do an alignment. It isn't that easy. If alingments were as simple as you state, you could just give a 'genius' a tape measure and a wrench and save yourself the $60,000 or so that it costs for a hunter 811.
Now, setting the toe is not very difficult, and I am sure you can get it close with your yard stick, but you have not shown a way of measuring camber and caster. I understand that since you have a soild axle you can't adjust those angles, but few people have that problem. Most have IFS and there is no backwoods way of getting your alignment accurate when you can't measure the other angles.
#46
Thats deglazing the rotor not trueing or turning the rotor, IMHO. If the disc is slightly warped, it would be very hard to true the rotor keeping both inside and outside parallel, and removing runout to thouandths/ten-thousandths of an inch, using nothing more than a grinder or sander.
#47
Ask Bruce about the camber and caster, he knows more about this than I.
#48
this is one of my favorite threads....good discussion, if not bordering on the immature name calling...but other than that, I think its a pretty good discussion, and hope to see someones mind changed here one way or the other....keep it up.
#49
a typical deglazing job can be done, by simply using a piece of sand paper and hand sanding a cross hatch pattern. The method I'm describing, actually goes a bit further. Technically speaking, the rotors are being turned. The process uses a 4 1/2" high speed disc grinder with a sanding disc attachment. With the rotor spinning, you gently run the disc 90 degrees to the rotation, on the rotor. Because you have two separate motions, the surface is taken down evenly. Rotors usually wear grooves in them, when trying to install new pads, they won't make full contact, that's why you have them turned, by grinding the surface, your removing most of these groove, this gives the pads an even surface to quickly seat on, if a small groove is left in the rotor, the pads will eventually conform to it. You'd be surprised just how close to tolerances you can get with this method.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
