Tube frame Yota pickup 84-88 race truck
Decided to join this website because I doubt anyone will enjoy this project as much as you all will.
this spring I’m build a full tube frame chassis 84-87 yoter pickup. It will be built to 350-450 hp on pump gas, a Ford 9 in on KW/ST suspension. I’m having a tough time deciding on wheel size. 15’s look infinitely better on these little trucks, but 17’s perform better in just about every way, *assuming* both wheel sets are roughly the same weight. Truck will be a street/road course machine, and road legal in Indiana.
I haven’t decided on a motor swap yet, but it will be “front mid” engine, the firewall will be bumped back quite a bit to make it happen. Transmission will practically be my passenger. Once I decide on wheel size, I’ll decide on brakes and rotors, but assuming we don’t build this chassis with a bunch of unnecessary tubing, it’ll be crazy light.
anyways, there’s the briefing for the build. Once it begins I’ll link my YouTube!
-Jay
-Jay
Then tape over the foaming area from side to side with a 2" wide piece of tape. Covering all repair areas. this forms a slight dome for the foam to push against to force it into the other foam for you instead of a spreader. It also gives you a surface to press on to push it in more flush like you were doing once it started solidifying.
snaptube vidmate
snaptube vidmate
jimjamn92
32
Mar 5, 2013 02:00 PM
