Transfer case sensor? Help!
Old May 4, 2008 | 04:56 PM
texcat101's Avatar
I just swapped in a low mileage '87 A340 Auto tranny with a new torque converter to replace my weak original 85 auto. The newer transfer case has a sensor with 2 wires that did not exhist on the older transfer case otherwise it's an exact match. I assume my transmission controller and computer won't even recognize it and maybe I should just unplug it, but I would like to know what it is and how it fits into the big picture. Does anyone know what this sensor is, and why it's not on the '85?
Old May 4, 2008 | 05:00 PM
LTrunner's Avatar
usaly there is 1 sensor on the t-case...the 4WD light sensor
Old May 4, 2008 | 05:50 PM
texcat101's Avatar
My 85 is not an SR5, very basic pkg I don't think I even have a 4wheel drive light.
Old May 4, 2008 | 06:24 PM
DeathCougar's Avatar
All 4x4's had a 4x4 light
There should be a few sensors in the 87 t-case that are not there in the 85, and I believe it has something to do with the ETC. not 100% sure tho
Old May 4, 2008 | 06:35 PM
R.DesJardin's Avatar
Sensors
I know my trans. has two Vehicle Speed Sensors, one on the side of the trans. and one where the speedo gear is at the rear.
Old May 4, 2008 | 06:43 PM
texcat101's Avatar
This transfer case has one sensor, perhaps the 85 setup got it's source from the shifter instead of the t'case
Old May 5, 2008 | 06:33 AM
mt_goat's Avatar
Got pics?
Old May 5, 2008 | 10:06 AM
texcat101's Avatar
Here is a picture thank's for your help
Old May 5, 2008 | 10:46 AM
mt_goat's Avatar
Yeah looks a lot like this 4WD indicator switch from a gear driven t-case. If so, it just switches the dash light on.
Old May 5, 2008 | 10:57 AM
texcat101's Avatar
I would bet you are right, if my light doesn't work then I will find the circuit and wire it in.
Funny though the 85 must have pulled it's source from the shifter or some other way.
4x4-runner
Apr 18, 2017 09:08 PM
4x4-runner
Dec 27, 2016 01:58 PM
Chumlee780
Nov 13, 2015 03:18 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
