Toyota 92 22RE with Broken timing chain-
Old Jul 23, 2015 | 05:52 PM
Littlerick's Avatar
I have a 92 toyota pickup with a 22re engine and dimming chain broke want to know if the engine is interference or non interference motor and if it possible bent the vales or not. Thanks
Old Jul 23, 2015 | 06:05 PM
millball's Avatar
Likely that some valves got bent.
Old Jul 23, 2015 | 06:08 PM
Littlerick's Avatar
How can u tell without pulling the head
Old Jul 23, 2015 | 06:26 PM
millball's Avatar
You might check the valve lash.
Any valve with excessive lash when its cam lobe is on its base circle, is likely bent.
Robert m's Avatar
Do a leak down test maybe?
These engines are very much an interference engine so the chances of a valve not being bent are not good
Old Jul 24, 2015 | 02:52 AM
Littlerick's Avatar
Do need to take the head of and have it tested and redo the vales
Old Sep 10, 2015 | 08:57 PM
ahmad1's Avatar
If the valve lash is found to be OK, do the compression test.
matrad
Aug 26, 2024 08:21 AM
voiddweller
19
May 2, 2016 09:10 PM
DacodaYota
Sep 2, 2015 02:13 PM
yamaha73
Jun 18, 2015 06:19 PM
infinityisfive
Jun 16, 2015 06:51 PM
