Tire pressure!
Old Dec 2, 2008 | 02:37 PM
91Toyota's Avatar
Tire pressure!
I'm running 27.5" Swampers on the rear of my 2wd Toyota. I don't know what tire pressure to use. My front tires are approx. 26.3" AT's. I am running 40psi in the front and 35psi in the swamers. It seems to sway all over the road. What should the tire pressure be?
Thanks!
Old Dec 2, 2008 | 03:11 PM
Adam F's Avatar
Use the chalk method.
Make a mark with the chalk all the way across each tire.
Drive for a short distance, a straight line is best.
Note the wear pattern in the chalk. If there is chalk left at the edge the tire is over inflated. Chalk left in the center means it's under-inflated. When the chalk is worn off evenly, the pressure is just right
Old Dec 2, 2008 | 03:27 PM
91Toyota's Avatar
Thanks! Never thought of that! Guess I should give it a shot!
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
itzmywife's
Jul 25, 2015 04:55 PM
skoti89
Jul 8, 2015 12:05 AM
