Timing chain job
Old Feb 7, 2009 | 08:44 PM
hmmwv15's Avatar
okay sweet. I'll have to find a good piece of oak to use, maybe I can get something to work!
Old Feb 8, 2009 | 11:30 AM
hmmwv15's Avatar
Read the haynes manual and they had a chain wrench to hold the crank pulley in place. A quick visit to the auto parts store yielded new radiator hoses, belts and the $20 chain wrench. Made the job easy, got that thing off in no time. I've got all the new parts in place. Now I have to wait for work tomorrow to get the parts cleaned up and the cover welded. Hopefully I'll have at least the front cover on tomorrow, if not tuesday.
Old Feb 12, 2009 | 01:46 PM
hmmwv15's Avatar
Well I have it all back together and it runs. Only problem is that I'm not getting any torque -or, not as much as I did-. The only thing I can think of it that when I set the timing w/ the timing light, the mark on the crankshaft pulley was at the 1 on the oil pump tab. I moved it all the way to 0 (where I thought it was supposed to be). Do you think it would make that much difference? I drove it around the neighborhood and it did okay, but when I put the pedal to the metal it didn't respond like it should. It barely made like it was trying to accelerate. Help would be very much appreciated.
Old Feb 12, 2009 | 02:26 PM
83's Avatar
83
Can't remember do you have an r or re? R's are meant to be set around 5 with the disty vacuum advance plugged. Mine's actually up around 8 but I'm up at a higher elevation. Worth a try.
Old Feb 12, 2009 | 02:39 PM
  #25
hmmwv15's Avatar
Well, I just set the timing back to 1, It's an RE btw. I get a little more torque, but it does the same thing as before. I forgot to mention that when it is at a lower rpm and you gas it, it makes a puttering sound if that makes any sense. I don't know what to do... I'd hate to take it back apart, but it looks like that's going to be my only choice.
Old Feb 12, 2009 | 02:44 PM
  #26
tampabayota's Avatar
that tool is bad azz can i put a patent on that
Old Feb 12, 2009 | 03:28 PM
  #27
surf4runner's Avatar
weekend job easily!
i did mine in front of my condo (that doesnt permit much work to be performed)
Originally Posted by hmmwv15
What other problems did you run into?
i had major crank bolt issues. broke my impact and the shops(AAA towed both ways) 1/2" drive + a bunch of sockets. gotta love lifetime warranties.
ended up being chiseld off
Old Feb 12, 2009 | 03:57 PM
  #28
hmmwv15's Avatar
Well, I appreciate the responses even though they are a bit late. If you would, read posts 23 and 25. Thanks
icentropy
Sep 16, 2020 02:47 PM
jerusry
Oct 19, 2015 05:28 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
