For those of you with OBD-I, monitoring your MPG is simple!
Old Jul 12, 2009 | 11:57 PM
24Runna's Avatar
I've been researching this for a bit and have yet to purchase or build one but figured I would post it up anyways.
It's called the MPGuino. It basically uses vehicle speed and fuel injectors.
Theres a few things you can do. You can build your own completely and buy all the parts and do a very good amount of soldering (~$40), buy a kit (~$39.51) or a completely built one for (~$63)
Here's some more info, and some more.
Constant 12V+ White Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/Yellow Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake Green/White Brake Switch
Tach Black Diagnostic Connector
VSS Wire Green/Orange ECM behind Glove.22 Pin Connector
Pulses Per Mile 4000 PPM
Hope this helps anyone wanting to go about this!
Old Jul 14, 2009 | 03:40 PM
Justinlhc's Avatar
Not sure how many have a VSS? I thought most were cable driven?
Old Jul 14, 2009 | 07:29 PM
Adam F's Avatar
Sometime in 91/92 they went to a VSS
Old Jul 14, 2009 | 08:24 PM
24Runna's Avatar
Adam F is right. Sorry should have said that!
Old Jul 15, 2009 | 06:52 AM
Adam F's Avatar
Why is this OBD1? Why couldnt this work with OBDII?
Old Jul 15, 2009 | 03:47 PM
Justinlhc's Avatar
Just a guess, but I would think it has to do with the impedence of the OBD2 injectors being different than the OBD1 injectors. I can't think of any other reason other than OBD2 being touchy about certain things.
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
mreagen
Oct 5, 2015 04:27 PM
93RedKrawler
Sep 29, 2015 02:50 PM
kawazx636
Sep 29, 2015 08:22 AM
