Tacoma 2006??
I don't mean to call you out, but are you saying the 05+ Taco has a less capable suspension?
The 05+ and 03+ 4Runners have nearly the same suspension as the previous generation. Not to mention, they now come stock with a negative CV angle, making them more friendly to lifts. Also, the TRD Offroad package comes with a "softer" sway-bar to allow for better flex. How is this less capable?
I just dont understand...
Buy the 06, and don't look back.
Having said all the above I think the new Taco's are a nice truck and I'm sure they're still quite capable and can probably go into about 90-95% of the places the previous TRD offroad Taco can, but if you told me to pick a Toyota truck from any generation to offroad in it'd be what I currently own or a 98-04 Taco with the offroad package.
Like I said I think the 05-07 Tacoma's are a better well rounded truck. If I had one the first thing I'd do is put a 1-2" coilover or coil spacer lift upfront and I'd probably chuck the entire rear spring packs for something aftermarket with some real carrying capacity. Perhaps it'd firm up the ride a bit but it's a truck for f's sakes!
Coednaked, i'm intersted in what you said about the leaf suspension but i don't fully understand about the springs being outside the leaf vs inside. I will definatly be adding a lift to my truck so i'm not sure what relocating the spring entails (cost and labor friendly wise). Could you shed some light on this?? Thanks
#25
#26
Well i'm still doing my research. Cruzing around other forums it sounds like its not uncommon to the 05+ taco's to lose there "rear end" even from just driving their trucks on the pavement. So can anyone shed some light on what "loosing your rear" means?? Thanks for the great replies, this forum has been really benificial. I've definatly appreciated your input CoedNaked! Im still having a hard time letting of the fact that i might not puchasing a (now) 07 taco.
#27
sbikes,
I haven't read any threads on other boards about guys loosing their rear end.
The expression loosing your rear end probably relates to a guy's rear differential grenading on them. No rear gears/differential (which is your rear end), and you're sure as hell not going anywhere as that is an extremely important part of your drivetrain. It basically transfers the twist/torque/power from your engine/transmission/driveshaft to your rear tires to move the truck.
I have read a few payload threads on the new Tacoma and lots of guys weren't impressed with the fact their new Tacoma's bottom out fairly easily.
The only way to remedy this is to get new spring packs or do an add a leaf to get extra payload capacity.
If I were you I would just get the 07 Tacoma. I'm sure it will cover your needs just fine. Like I said I think it will probably get you into 90 to 95% of the places a previous generation stock Tacoma with the TRD package will go. This truck has more power, and it's got some nifty new features and it's the most comfortable compact/midsize truck Toyota has ever produced as far as creature comforts/versatility.
#28
Hey thanks for your helpful responces Coed. Its been really helpfull in getting a better understanding and handle on what my money's getting me! ttora is the forum i read about people's rears failing for 05+. Lotts to research and learn, i may wait a month before i buy. Definalty going to research the new engine. I know the 01-04 engines are some of the best! Thanks again
#31
There have been about 6 reported cases of Blown rearends on 05 Tacoma TRD off-roads and more than 6 people with FJ Cruisers including one of the Trail Team Trucks. These vehicles share rearends, the Toyota 8" with e-locker.
Regarding this issue with Tacomas it is only an issue with a TRD off-road, the TRD Sports and Sr5's all have the larger rearend that comes in Tundras and there haven't been any reported failures of these rearends in Tacomas.
#32
Rivalred, i actually ordered an 07 taco, price out the door is 26,100! Though this was a sweet deal and i'm excited about my new ride! Sandpearl black, oc & TO package, manual transmission. Definatly hope i don't loose my rear, but it seems like a bigger issue on the 05's
LCE_Performance
Oct 1, 2015 01:03 PM
bryan34w
12
Sep 30, 2015 02:50 PM
