T-Case Brake
Old Oct 12, 2006 | 12:10 PM
Bill's Avatar
T-Case Brake
How many people are using T-case brakes, and where did you get them?
I'm looking to get one for 3 reasons:
1: I don't currently have an e-brake on my truck, and need one.
2: a t-case brake seems to be about the same cost as getting new cables from Toyota
3: I plan to do a rear disc swap in the near future, so will need one then anyways.
I've seen Allpro's t-case brake, and Sky Manufacturings. But are there any other options out there?
Old Oct 12, 2006 | 12:35 PM
waskillywabbit's Avatar
I have the All-Pro one and it works great.
Old Oct 12, 2006 | 12:52 PM
NPE701's Avatar
Does anyone make it for 3rd Gen 4Runner?
Old Oct 12, 2006 | 12:58 PM
mastacox's Avatar
Unless your rear is locked I don't think a T-case brake is a very good replacement for e-brakes, especially if you live in hilly country.
My 0.02
Old Oct 12, 2006 | 01:04 PM
RunnerUp's Avatar
nope! i did the all pro disc brake swap awhile back, and have no parking brake, which sucks, and which all pro didnt tell me before i bought their kit. dont get me wrong, i love the disc for ease of cleaning/more stopping power. but iw ant my parking brake back! if anyone can figure out a solution for 3rd gens please post up... i need a parking brake
Old Oct 12, 2006 | 01:58 PM
AH64ID's Avatar
My 0.02
Wouldnt one tire have to spin fwd and one backword for this to fail?
I understand what you are saying, but I dont think it would be an issue...
Old Oct 13, 2006 | 07:29 AM
Bill's Avatar
Well, I ordered an Allpro brake last night, pretty good shipping rate considering it's UPS and across the border.
I guess its time to get my ass moving on my tranny swap so I can actually use it when it gets here. stupid automatic
Old Oct 13, 2006 | 08:37 AM
garrett1478's Avatar
this is the closest you'll get for a 3rd gen 4Runner:
http://ttora.com/forum/showthread.php?t=43900
it will take some customizing though because the parking brake in 4Runners come out of the body behind the transfer case...
Old Oct 13, 2006 | 12:45 PM
RunnerUp's Avatar
hmm... i wonder how much customizing? any one know? if its not that hard to modify it to make it work then it would so be worth 200$ to me.
Old Oct 13, 2006 | 01:13 PM
aviator's Avatar
Could you not fab a mount to attach the brake to the nose of the rear diff? would this not give you usable E-brake again? I've seen some pretty small ones that would not affect the ground clearance to much...
Old Apr 11, 2007 | 08:18 AM
joeylead's Avatar
any new information on this yet? I am looking into a t-case brake now. My rear is open, but will be locked soon. Any more infor would be great.
Old Apr 11, 2007 | 10:10 AM
Bill's Avatar
Not really "new", but something I guess.
I got the brake installed, and aside from needing to fiddle with some cable routings(my ebrake cable it WAY to long to use as is). It was a pretty easy instal.
I've been rebuilding my engine...a couple times because bad stuff has happened. I havn't gotten a chance to drive with it yet, but I can tell you that it will certainly hold the crank in place. I've found I can get the same effect by applying the t-case brake as I get having the t-case in 4-Hi and the tranny in 5th.
I'm happy with it thus far...as for the $67 UPS charged me in brokerage...that's another story.
Old Apr 11, 2007 | 10:57 AM
bob200587's Avatar
Does the All pro kit come with everything you need? Does any one have a write up on the install, or does it come with detailed instructions?
Old Apr 11, 2007 | 11:13 AM
woolsocks's Avatar
have you thought of using a line-lock?
Old Apr 11, 2007 | 07:01 PM
Stomis's Avatar
This isnt the only solution for ebrake on a rear disc swap. I beleive Sky sells a kit that uses Chevy rear calipers and rotors that have an ebrake integrated.
Old Apr 12, 2007 | 12:31 PM
Bill's Avatar
Yeah, I looked at that too. You can use Cadillac ElDorado calipers or Ford tarus calipers, both have integrated e-brakes, but both are really expensive and I've heard the caddy calipers are a PITA to work on/with. If you wanted to go to a full floating axle, you could also use a set up with the internal drum style parking brake like the Supra or FJ crusier use. FROR's full floater kit has that as an option.
I want to do a disc swap that's as simple as possible, and this works so I'm happy.
As for a line lock: NOT good as an ebrake. They work great for temporary stops, but can loose pressure and thus release your brakes. Plus in Canada you have to have an e-brake that can be operated independantly of the cars regular braking system.
And on the instal: it come with directions(as good as you need), and it's pretty straight forward: pop off the drive shaft and flange, bolt the disc on. Then pull some bolts from your t-case, line up the caliper and replace with longer bolts. The only tricky part is hooking up the ebrake cable. Mine too a bit of rerouting to get to work properly.
Old Apr 12, 2007 | 02:58 PM
Adam F's Avatar
Yes it would. Even then they would move at different speeds which would cause the d-shaft to spin, so the tcase brake would prevent that.
Rowdydudeman
Nov 26, 2015 02:17 PM
old87yota
Sep 9, 2015 12:39 PM
Scatterbrain
Sep 3, 2015 06:46 PM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
