from synthetic blend to regular oil
Old Nov 23, 2006 | 09:51 AM
JEDI87's Avatar
I am thinking of swithing back from synthetic blend to regular oil.I know it's ok to switch from regular to synthetic and I know you're not supposed to mix the 2 but is it a problem going back to regular oil?
Old Nov 23, 2006 | 10:19 AM
Knuckles's Avatar
no, i work at a lube shop and people do it alot.
Old Nov 23, 2006 | 10:51 AM
Jboy's Avatar
I go back and forth either way (that really doesn't sound good lol) and notice nothing wrong.
Old Nov 23, 2006 | 11:55 AM
91TPU's Avatar
if u went full syn, and u had been driving on full syn for a couple of oil changes i would say stay with syn, it lubricates better and doesnt lose its viscosity as much as dino oil. you can switch back and forth, but im not really understanding why u would wanna do that, dino is only a few dollars cheaper then syn blend. if its cuz you have a leak, imo its not gonna change anything there.
Old Nov 23, 2006 | 12:14 PM
JEDI87's Avatar
I don't have any leaks but my 87 goes through oil pretty quickly and I would rather use a good regular motor oil than dumping in blend every week.
Old Nov 23, 2006 | 04:56 PM
AH64ID's Avatar
Are you burning it?
There is nothing wrong with mixing or swaping back... but syn is a much better oil, even if your burning it...
Old Nov 23, 2006 | 07:20 PM
JEDI87's Avatar
It doesn't blow smoke but it goes through about a qt. every 600 miles or so. I'm sick of dropping double the money on the oil. The motor only has about 7,000 miles, if that.
Old Nov 23, 2006 | 07:34 PM
91TPU's Avatar
if the motor only has 7k on it since it was rebuilt, and your burning 1qt of oil every 600 miles, i would say that you have more of an issue with what your motor is doing rather then what your putting into it.
Old Nov 23, 2006 | 07:36 PM
JEDI87's Avatar
I don't know what it is, no smoke, runs great, I get about 22 mpg's. It just uses oil.
Old Nov 23, 2006 | 07:40 PM
91TPU's Avatar
blowby?, leak somewhere?
Old Nov 24, 2006 | 02:26 AM
AH64ID's Avatar
How much oil?
Old Nov 24, 2006 | 05:54 AM
JEDI87's Avatar
If I drive it for a few weeks (250 miles a week), then I usually have to put in a qt about every 2-3 weeks. It doesn't leak a drop.
Old Nov 24, 2006 | 08:49 AM
uberhahn's Avatar
I have the same issue with mine. No burning, no leaks.
My problem was that the valve cover gasket developed a small leak around the sparkplug hole, and oil was weeping through.
Changed gaskets and voila, no more oil usage.
uberhahn
Old Nov 24, 2006 | 09:31 AM
JEDI87's Avatar
The only smoke I get is when it's the first cold starup but it's black do to my 250,000 mile injectors leaking. I have to pop the cover and do a rocker adjustment so I'm going to double check everything.
Old Nov 24, 2006 | 09:43 AM
rollem's Avatar
I bought my truck 93 pu v6 4x4 about a yr ago and they guy I bought it from had synthetic in it. It had a leak at the back of the valve cover. I switched to regular oil and the leak went away.,, Go figure. I think synthetic caused the leak on my 130k motor. Anyways I also burn a bit of oil aswell. I think it's the nature of the beast.
Old Nov 24, 2006 | 09:47 AM
JEDI87's Avatar
Yeah I'm sure it's nothing bad with the motor and it's just going to do it. I'm not worried about it. I'm wondering if the oil will last longer with the regular oil.
Old Nov 24, 2006 | 11:02 AM
SLC97SR5's Avatar
What engine oil did you break the motor in on? If you used synthetic or blend I belive that's your problem. Dino oil needs to be used to allow the necessary wear to occur between the cylinders and pistons.
Old Nov 24, 2006 | 11:13 AM
JEDI87's Avatar
I used regular valvoline 10w30
Old Nov 24, 2006 | 11:20 AM
Elton's Avatar
i use regular oil my self as i dont see a point paying 20 bucks for synthetic
Old Nov 24, 2006 | 03:22 PM
AH64ID's Avatar
Synthetic didnt cause the leak.. it was there. Its just that synthetic cleaned up the seal and make the leak more noticible, and then has a easier time getting thru. When you put dino back in it doesnt clean seals like syn so it got plugged again, but the hole for the leak is still there...
Then you havent realized the benefits of synthetic. Change your oil once a year or every 25K, filter every 5K. Even with as little as 15K miles its still cheaper... and better for your engine. Throw a bypass filter on there and you can go 10K on a full flow and 25K on a bypass.... it causes less wear, and lasts longer.... really its cheaper... kinda like buying a toyota... a little more $$ up front but at the end it was cheaper...
