swap V6 third into SFA
Old Jun 23, 2008 | 06:01 PM
HAVOC's Avatar
Question swap V6 third into SFA
I've searched but couldn't find anything (I must be using the wrong search terms).
Can I put the differential from a V6 rear axle into a solid front axle? Will all the bolts line up and the axles fit? I have the parts to do the swap, but I need to disassemble and clean everything first.
I know the gearing will be different. I'll address that at a later date.
edit: Turns out that you can swap the two diffs. Now to find another V6 diff...
Old Jun 23, 2008 | 06:26 PM
DeathCougar's Avatar
Yes, you can.
However, if you plan on using the 85 driveline, you may have to change the flange on the diff.
Old Jun 24, 2008 | 04:44 AM
Yoda's Avatar
We had the rear diff from a 90 V6 runner in the front of an 85 with no issues
ChefYota4x4
Jan 14, 2016 05:02 AM
4RescueOR
Jun 26, 2014 11:11 PM
rAvery
Apr 17, 2014 08:12 PM
clonman123
Engine Swaps
Dec 5, 2013 12:48 AM
