Spare gas can
Old May 22, 2006 | 10:32 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Spare gas can
How many of you all carry a full, spare gas can on a normal basis? Do most of you all just carry a full one on the trail? Where do you carry it? How big is it? For you truck owners, is it a bad idea to leave a full spare can in the tool box? Would that get too hot? Thanks!
Old May 22, 2006 | 11:27 AM
kyle_22r's Avatar
i wouldn't recommend carrying a gas can inside your tool box, if it leaks, vapors can build up and create a dangerous situation.
Old May 22, 2006 | 11:30 AM
snap-on's Avatar
i usually dont need one/carry one when wheeling in the midwest.
when i head out west i carry (2) 5 gallon NATO cans packed into the bed somehow. location changes depending on what other gear im carrying.
Old May 22, 2006 | 11:34 AM
Corey's Avatar
Co-Founder/Administrator
This is where I carried mine for years on my Load Warrior.
Carried it empty unless I was on a run.
Got it at www.generatorjoe.com
Leak proof can.
This is the 2.5 gal one, not the 5 gal one.
http://www.pnw4runners.com/runs/41203/14.jpg
http://www.pnw4runners.com/runs/41203/11.jpg
http://www.pnw4runners.com/runs/41203/7.jpg
Carry the can outside, never inside.
Old May 25, 2006 | 12:42 PM
boogyman's Avatar
where's a good place to buy a 5gal metal can? I can't seem to find them anywhere.
Old May 25, 2006 | 01:02 PM
Glenn's Avatar
I sometimes carry a Blitz 5+ gallon plastic gas can for extra fuel. It fits under the tonneau cover and goes in the corner where it can't tip over easily. The only problem with it is that it's hard to get all the fuel out. The spout won't bend far enough to get the can upside down to drain it all out. I end up siphoning the last of the fuel out to get it all.
Old May 25, 2006 | 01:14 PM
kyle_22r's Avatar
you may be out of luck in california, probably have to cross the state lines to find a "good" can instead of that ventless BS.
Old May 25, 2006 | 01:51 PM
Scottiac's Avatar
I wanted the plastic military scepter can, so I ordered it from
http://offroadrecovery.zoovy.com/product/SCP11
I got the "carb approved" nozzle for it. COMPLETE PIECE OF DUNG.
It very effectively kept vapors from escaping. But the nozzle wasn't long enough to get into the gas tank, so instead of letting some miniscule amount of vapor escape, I poured gasoline all over the truck, the street, my shoes....
I then just ordered the non-carb one, neglecting to mention that I was in california. Arrived no problem, much happier.
They have the metal blitz cans too, but if you just want those, go to central 4wd (one of them on auburn, and there's another one somewhere off of I-80) and get it directly.
Old May 25, 2006 | 02:02 PM
Tanto's Avatar
I have a 5gal plastic can that I got at Kragen's Auto parts right before the DV trip. I only take it when I'm going to be spending the night on the trail since that usually means more driving during the day. Only thing I don't like about mine is that I need the extended nozzle (which is not permanently attached to the can ) to completely drain the can. I just ratchet strap it to the side of my bed.
Storing it in a tool box is a bad idea IMHO.
Old May 25, 2006 | 02:24 PM
1985 4Runner's Avatar
I carried mine here for a few weeks, then relocated it on the tire carrier, above the "impact zone"...
eBay link to metal gas can.
Old May 25, 2006 | 03:08 PM
Jimmeh's Avatar
I have a gas can in the back of my dads pickup at all times, because his trucks gas gauge doesn't work. I haven't seen it empty yet, but my fear is that somebody will either swipe it or put all the gas in their car, and then drive away leaving me with an empty can.
Old May 25, 2006 | 03:32 PM
Robinhood150's Avatar
I carry the gas can but I never have gas in it unless I expect to go on a long trip where gas can be scarce, like DV. It's too dangerous to keep gas like that.
You can't get the good gas cans in Ca, too many eco nazi's. And like scottiac said, the bad ones spill everywhere and leak. I imported mine from Arizona.
Old May 25, 2006 | 05:07 PM
Scottiac's Avatar
Actually, the place I mentioned will ship the good cans to California... But I was trying to be a good Kaleefornian and get the CARB nozzle. That was the part that stunk. The can itself has been excellent. Now that I have an "illegal" nozzle, all is good.
The specter water cans, on the other hand, leak like crazy... WTF?
Old May 26, 2006 | 08:34 AM
boogyman's Avatar
Talking
i went down to central off of hwy 50 (on folsom blvd) and they want $60 for the blitz can. forget that. i'll check out that link you posted.
Old May 26, 2006 | 08:51 PM
4x4Lamm's Avatar
I have the 2.5 gallon plastic Sceptor cans starpped to my cargo basket when need be, but that is not often.
TJM makes a nice plastic can as well.
Also, I never bother with the spouts. I always just usa a "magic siphon".
Lamm
lectric80
Aug 11, 2015 12:02 AM
adammtb
Jul 27, 2015 11:57 AM
sabine
Jul 18, 2015 03:59 PM
skoti89
Jul 6, 2015 07:45 PM
