SeaFoam'd it. Not much difference. i do it wrong?
Old Oct 30, 2009 | 11:23 AM
tj884Rdlx's Avatar
i've always felt the truck was a little sluggish, but i'm running 33's with a 22re and 4.11s, so i know it's slow. but the acceleration is also not consistent.
at about 3400 rpm, the acceleration increases like i have a secret mini-turbo somewhere. i figured a SeaFoam treatment might help with the lower end.
i figured that going as far to the front of the intake as possible would clean more of it. so i pulled the hose from the a/c idle up, plugged that, and then stuck the hose into the can.
you can see the hose i used in this pic. it elbows to the intake from the driver's side of it, and attaches IMMEDIATELY BEHIND the clamp for the big black intake elbow, on the top.
it sucked in half a can as i held about 2k rpm, then i shut it down for about 5 mins. i rehooked all, and started it up. had to WOT to get it to turn over.
it smoked, but not a thick white cloud. it cleared in about 5 mins.
i don't notice any performance improvement. would doing it again through the brake booster be worth it, or is it just not that dirty in there?
Old Oct 30, 2009 | 11:29 AM
fastrob691's Avatar
When i did sea foam through the intake on my 92 my neighbors called the fire department, dead serious, had to explain to them that i knew what i was doing and the 100ft cloud was supposed to look like that. They took my empty can for the report, so they could highlight the instructions. Maybe yours is really clean, mine was not. I ran it through a strong vaccuum source, i believe off the cruise junction/solenoid.
Old Oct 30, 2009 | 05:06 PM
yoterr's Avatar
theres a sea foam thread on here somewhere, but ur supposed to kill it with the seam foam and pour like an 1/8 of it in there after it dies, now this is extremely hard with an EFI motor but they sell sea foam deep creep i think its the same stuff just n a spray can so u can spray it threw the throttle body
Old Oct 30, 2009 | 08:24 PM
Adam F's Avatar
Keep in mind, seafoam is not a miracle in a bottle. Sounds like you have other problems, seafoam will not fix it.
Could be clogged fuel injectors. When did you change your fuel filter last? If its been a long time, change it, cut it in half, and look for crud. If its clogged, then so are your fuel injectors.
Try running some ATF in your gas tank. Let the tank get to close to empty, and dump a quart of ATF in. Run it for a while, and see if it helps.
Old Oct 31, 2009 | 03:08 AM
TinMan's Avatar
adam f do you mean let the tank get close to empty put a quart of atf in and run it like that, or fill up the tank again after you put in the atf?
I sea foamed mine last week, used the brake booster hose, runs really crappy when you pull that hose off, but once I started pooring in the sea foam it will smooth out. put in about a 1/2 can then shut it off for 5 min. Found an exhaust leak aroung the exhaust man to down pipe connection. When I started it up it filled the block up with smoke. Ran it for about an hour and it still smoked. finally stopped smoking just the other day. But the power increase was unbelievable. Put the rest of the can in the oil. I will change it out tomorrow. I was hoping it would help out my valve seals, but has not changed the oil consumption any.
Old Oct 31, 2009 | 03:25 AM
92 TOY's Avatar
Slightly off topic but still on the subject of SEAFOAM.
Can I use it and a old toothbrush and scotchbrite pads to clean myvalves and piston tops while I have my engine mostly disassembled.
I was told to use brake cleaner, which I haven't gotten yet, but I do have seafoam.
Back on topic...would there be any downside to doing the treatment a 2nd time for the question in the original post? Or is there a better place to use to suck in the seafoam? I have not done that ever.
Old Oct 31, 2009 | 01:18 PM
desertcamper67's Avatar
I used it and was not impressed. Later I took off my intake and physically scraped off a bunch of buildup. It took years to build up so a bottle of chemicals isn't going to put much of a dent in it. At best, I think it may have softened up the caked on stuff.
Old Nov 1, 2009 | 12:29 PM
AzStorm's Avatar
https://www.yotatech.com/forums/f105...-truth-160613/
Old Nov 1, 2009 | 01:27 PM
phildelfino's Avatar
I use the brake booster hose. One treatment should be 1/3 can in gas tank, 1/3 can in vacuum hose (then shut it off for 25 - 30 minutes to let it soak in) and 1/3 can in oil. I use it in the oil 2-500 miles before oil change. Don't know how much good it does this 230,000 mile V6 in my 88. But I feel it doesn't hurt any, so I will continue.
Old Nov 2, 2009 | 10:44 PM
Cal01's Avatar
^ i do the same
1. 1/3 in the brake booster hose. turn off engine
2. pour 1/3 in the oil
3. pour the rest in the gas tank
wait for 10min and start it up. rev some till smoke somewhat clears...then drive around the block.
4.change oil
for mines i had better response. for older cars you might get exhaust leaks...
Old Nov 2, 2009 | 11:10 PM
camo31_10.50's Avatar
i do about 3/4 in the intake..(over a few hours time) and then 1/4 in the tank just for the heck of it..lol
never put it in my crankcase..my oil stays clean..and i dont leak MUCH..lol of course it's rebuilt..LOL
Old Nov 2, 2009 | 11:11 PM
i also did mine at the local carwash on a cruise night....had A LOT of guys come around askin me if somethin was wrong...i smoke that biatch out hahahahhahahahaha..it was hilarious....
Old Nov 4, 2009 | 09:37 AM
Adam F's Avatar
Yes, run it with a high amount of ATF in the gasoline. ATF has a high level of detergents and it will help clean out any junk in the fuel lines or injectors.
Old Nov 4, 2009 | 09:39 AM
theAuthority's Avatar
User Requested Ban
Did you run it with any snake oil or elbow grease?
Old Nov 4, 2009 | 05:29 PM
90-3vzeslug's Avatar
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/D11ZVYwj62w&color1=0xb1b1b1&color2=0xcfcfcf&featur e=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/D11ZVYwj62w&color1=0xb1b1b1&color2=0xcfcfcf&featur e=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></embed></object>
It goes through the pcv valve hose. this feeds all cylinders thoroughly. It will work this way!
Old Nov 4, 2009 | 05:30 PM
damn link!
www.seafoam.com and click on the fuel injector cleaner video is halfway or so down the page
Old Nov 5, 2009 | 07:23 PM
Adam F's Avatar
lol
Old Nov 6, 2009 | 01:52 AM
TinMan's Avatar
Now thats thinkin with ur dipstick.
Old Nov 7, 2009 | 06:56 AM
Originally Posted by Adam F
lol
YIKES I fail!
heres the real link this time. third times the charm.
http://www.seafoamsales.com/motor-treatment/index.html
at the bottom of the page is the video.
Old Nov 10, 2009 | 05:32 PM
tj884Rdlx's Avatar
well i must admit, that sea foam place does look very clean!
