Ramsey REP6000 Wiring help
Old Feb 18, 2007 | 04:59 PM
MorphiasX's Avatar
I am wiring up my Ramsey REP6000 winch with the Ramsey wirless remote, and im going to use the wiring harness that ramsey included. They included an adapter to plug into the normal 3-pin winch remote plug, but I got my winch used and the plug was missing, hence the reason I am using the supplied harness. Although they supplied the harness, they did not supply a wiring diagram. Anyways there are three wires, green, yellow, and red. Basically I just need to know what wires go to where. I know that two go to the solenoids (one to the in solenoid, and one to the out solenoid). But where does the third one go? Ground? Positive?
Old Feb 21, 2007 | 08:24 AM
4Crawler's Avatar
Best to just trace the wires to see what they connect to. It is either a common power or common ground wire. In the switch that you plug in, you connect one or the other wire to the common to go in ot out. If you can visually follow the wire, an ohm meter or test light would tell you if it connected to power or ground.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
