Questions About Rims
Old May 23, 2007 | 05:08 AM
Mark in MD's Avatar
My wife's Subaru has rims that measure 17" from outside edge to outside edge. The car has 16 inch tires.
My Chevy Nova measures 14" and has 13" tires.
My Taco measures 17" and has 16" tires.
If you measure the rims from inside well to inside well, you get something less than the mounted tire size.
1) So what is the proper way to measure a rim? It seems to be "Measure the diameter from edge to edge and subtract one inch." Is this correct?
2) Somebody has told me on this site that I can't mount 15 inch rims on my 07 Tacoma. I must have 16" Rims. Why? Are the six studs on my Taco's hub spaced differently so that a 15 inch rim won't fit?
I am considering purchasing dedicated snow tires and rims for this winter and 16 inch rims seem hard to find than 15s.
Thanks
Old May 23, 2007 | 05:29 AM
pat161's Avatar
Usually the brakes are the probleem. 15" are not big enough to clear them.
Old May 23, 2007 | 06:17 AM
4Crawler's Avatar
How to measure wheels:
- http://www.4crawler.com/Diesel/Tires.shtml#WHEELS
Diameter and width are both measured where the tire bead sits, so hard to get exact measurements externally. Best bet is to look for the mfg. stamp on the wheel, will give both:
Old May 24, 2007 | 06:49 AM
Mark in MD's Avatar
Okay, thanks!
Jun 1, 2021 01:51 PM
chukarhunt
Dec 8, 2019 11:39 AM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
4x4-runner
Aug 3, 2015 07:14 PM
Yotoder865
Jul 9, 2015 07:51 PM
