Question about axle articulation
Old Dec 5, 2007 | 03:16 PM
88Yota4runner's Avatar
Question Question about axle articulation
ok, this may just be the stupidest question to some of you out there but i havent seen anything about it, so me being a no0b is sorry, but on a solid axle truck, do you absolutely HAVE to have leaf springs? i dont see what the point of having shocks is if you cant use them, wouldnt you want to get rid of the leaf springs to get more flex? i just need to know how you would obtain masive flex. and leaf springs just seem pointless
Old Dec 5, 2007 | 03:23 PM
BLKNBLU's Avatar
No it doesn't have to be leaf.
http://www.hunt4steve.com/
Old Dec 5, 2007 | 03:27 PM
how do you accomplish that? just get shocks and put springs around them and youre pretty much set?
Old Dec 5, 2007 | 03:32 PM
BLKNBLU's Avatar
Yeah just get some shocks and springs and bolt them on.
Old Dec 5, 2007 | 03:33 PM
AxleIke's Avatar
Well, you don't do that, a company does, as they are special, but that is the basic idea.
Those run 200-500 per corner, depending on what type you get. They are awesome.
Also, you can get a lot of flex out of leaf springs. You just have to pay for them, and build them right.
Old Dec 5, 2007 | 11:00 PM
Jay351's Avatar
Guys use leaf springs because:
Our frames (up to 1995) where pretty much the same since the factory solid front axle trucks. Since everything is in place, leaf springs line up perfect on the frame. Leaf springs are cheap and easy to work with, coils can be more dificult since you need to fab some sort of link setup to keep the axle in place. With leafs you get all that in the spring packs.
Old Dec 6, 2007 | 04:29 AM
AxleIke's Avatar
Originally Posted by Jay351
.....coils can be more dificult since you need to fab some sort of link setup to keep the axle in place. With leafs you get all that in the spring packs.
Lots more difficult. Leaf springs are, as stated, stupid easy. They flex well, give you a stable ride on the highway, and are damn near bolt on.
Links require a knowledge of geometry. While it is high school level stuff, considering most on the net can't even spell or punctuate, its a tall order. In addition to getting the angles and lengths exactly right, there are issues fitting them on the trucks. You have to clear exhaust, driveshaft, oil pan, yada yada yada. In addition, you often need a sway bar of sorts to make the truck stable on the highway, depending on the system. Since you put on the link set up to get a bunch of flex, the sway bar must be removable. This adds to the complication, but only slightly.
Essentially, if you have a truck that has a body that you care about, leaf springs vs coils/coilovers is a wash. You won't be limited in the slightest by a leaf spring suspension. If you are running comp buggies, that is a different story.
Old Dec 6, 2007 | 01:25 PM
bigarms23's Avatar
if you dont want leafs than i would suggest the ors coilover kit
Old Dec 12, 2007 | 07:38 PM
WCorbett's Avatar
I suggest you don't buy a single thing and read every thread on yotatech and a few on pirate.
Old Dec 15, 2007 | 08:09 AM
geTBeNt2NIghT's Avatar
ya wow you should try and run just shocks with no springs or links and see what happens...you'll get massive something...
Old Dec 15, 2007 | 01:46 PM
Island_Yota's Avatar
Well if it somehow managed to drive you would have a kow rider with custom axle wrap and bump stop suspension!
Old Dec 15, 2007 | 01:52 PM
Tacoclimber's Avatar
Originally Posted by AxleIke
...Links require a knowledge of geometry. While it is high school level stuff, considering most on the net can't even spell or punctuate, its a tall order...
Wow, isn't that the truth?
88yota, I actually would agree with those who have encouraged you to read. If you're really curious as to how these different suspension designs work, you can learn a massive amount just by reading what other have discovered through their own research and development.
It is nice to have something that works and know WHY and HOW it works.
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
Backcountry411
Jul 24, 2015 08:06 AM
