A Quality timing chain for little $$
Old May 14, 2008 | 04:13 PM
trailblazr81's Avatar
So the timing chain went out on my 88 4Runner. Just cruising I hear this dull "poof" and motor dead. Tow it home, rip off valve cover, and theres the gear with no chain. Guess its in the oil pan. I'm guessing the problem was that its a Japanese motor and the gear on the cam had "USA" stamped on it.
Anyway Im kind of leary of the $25 chain on Kragen's websight. Dont want/need anything hardcore, just want it to be reliable. What do you recomend for low cost high quality? And I'll replace the guides, but what about the tensioner?
Old May 15, 2008 | 05:42 AM
dirtoyboy's Avatar
Call Ted at Engnbldr.com......obviously you want a "Japanese" timing chain kit. I would recommend one with metal guides. Talk to Ted......he wont steer u wrong
Old May 15, 2008 | 08:22 AM
eric-the-red's Avatar
I thinkthe 22R is an interference motor, you may need more than a new chain
Old May 15, 2008 | 08:26 AM
norcalsvx's Avatar
call ted @ engbldr.com and make sure to get the metal guide
Old May 15, 2008 | 08:29 AM
linuxrunner's Avatar
I agree,
I have heard many reports of a broken timing chains with no ill effects on the 22r... But then i have also seen some serious damage from a broken t-chian with my own eyes, so cross your fingers.
Old May 15, 2008 | 08:30 AM
EWAYota's Avatar
x3. Ted rocks
Old May 22, 2008 | 06:45 AM
Red_Chili's Avatar
x4. He has always taken the time to explain all possible issues.
Old May 22, 2008 | 06:56 AM
rdlsz24's Avatar
Pray to the 22RE gods you don't have bent valves. If you don't I agree go with Engnbldr or OEM for the chain/guides.
Rob
Old May 22, 2008 | 07:42 AM
eightnine's Avatar
When the timing chain snapped on my truck it didnt bend any valves at all. Might have been a fluke tho.. either way just had to get a new timing kit. If you wana be on the safe side get an OEM one. They will be more expensive but they are the best quality. Look how long it lasted you so far.
Old May 23, 2008 | 12:31 PM
Matt16's Avatar
I broke my chain because some moron didn't use locktite on the t-chain guide bolts. One fell right into the timing chain when I started it up. I had no resulting damage to the valves.
BushPig
Oct 29, 2022 06:26 AM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
garagespace
Jul 9, 2015 08:37 AM
