putting a turbo on a 22re
Old Oct 20, 2009 | 05:39 PM
kolka4runner87's Avatar
I am thinking of putting a turbo on my 22re and i need help finding sites for the parts. If there is people selling turbo parts on here and tips on doing this. Thanks
Old Oct 20, 2009 | 05:40 PM
DeathCougar's Avatar
LCengineering.com
Waste of money IMHO. The 22RE motors were not really designed for a turbo setup, and wont last very long with one in stock form.
Old Oct 20, 2009 | 05:43 PM
camo31_10.50's Avatar
find a stock '86-'87 2RET?????
pretty sure the 22ret's had different combustion chambers (or so i've heard), and have the holes drilled for the oil (known as LAZER block), had lower compression pistons, and i know im missing other stuff..im no expert by any means..lmao but i know a little..lol
Old Oct 20, 2009 | 06:05 PM
toyota4x4907's Avatar
The laser block is '85+ 22r/e blocks, not specifically 22rtes
Old Oct 20, 2009 | 06:08 PM
The 22RTE blocks are however drilled and tapped to accept the turbo cooler oil return line
Old Oct 20, 2009 | 06:10 PM
exactly..lol
why get your own block drilled by a shop that probably hasn't ever done it before..when you can get a perfectly fine block drilled from the factory for the turbo..lol just makin it easier..at least in my opinion i am
Old Oct 21, 2009 | 11:58 AM
I was planning on rebuilding the block with low compression pistons and H beam rods. I am looking for how much boost I could run and were is a good place to drill the holes in the block for the oil. I like run as boost as it take. i am building this truck into a prerunner for the sand dunes. I like to keep the 22re instead of putting a v6 or v8 in it, because that is to easy to make more power. plus i like that turbo sound! if I can find a turbo block for sale somewhere by me I will go for that. I already knew of LCengineering.com is there other sites to look at for parts? Thanks for the help
Old Nov 9, 2009 | 08:08 AM
theblueox's Avatar
i have a black 87 ext cab 5 speed turbo pickup but it needs a turbo. It just went out a couple months ago. I am in virginia though. i want to sell it but will be working on fixing it till it sells. just a private message if you interested
Old Nov 9, 2009 | 10:22 AM
PM sent on the truck
Old Nov 12, 2009 | 02:26 AM
j-man's Avatar
go over to customtacos.com and youll find lots have turbo'd the 22re - go for it and dont look back.
Doug4320
Mar 24, 2018 10:11 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
karbin
Jul 5, 2015 11:37 PM
