Pinnion seal won't stop pouring
Old Jul 26, 2009 | 07:20 PM
aadown1214's Avatar
Hey yall, Im finally getting to the nickel and dime parts of the truck and cannot get the pinnion seal to quit leaking. I have swapped it, did not notice any groove worn in the pinnion, and greased the new seal as i put it in. The only thing that i can think of is that it got over torqued and smashed the seal. Is there a rough ft/lb that i should torque it to or jsut impact it? Trying to avoid tearing it apart, limited space and no pneumatics.
Old Jul 26, 2009 | 07:21 PM
aadown1214's Avatar
It is on the rearend by the way, didn't know if that's going to make a difference
Old Jul 26, 2009 | 07:36 PM
toyota4x4907's Avatar
Mine is leaking too. I've only had the truck for like 3 weeks and havent gotten around to fixing it yet. Make sure your u-joints are in good shape and driveshaft is balanced. I guess unbalanced drivetrains can wreak havoc on the pinion seals. good luck.
Old Jul 26, 2009 | 07:46 PM
4Crawler's Avatar
Pinion seal replacement guide:
- http://www.4crawler.com/4x4/CheapTri...eal/index.html
On the leaking, check your diff. breather to make sure it is not clogged. If it is, that can pressurize the axle housing and force oil out past the path of least resistance.
Old Jul 26, 2009 | 09:03 PM
aadown1214's Avatar
Touche on the vent, never dreamt it could have something to do with it, thank you!
sandyota
Feb 4, 2021 11:16 AM
trucker trash
Jul 28, 2015 10:09 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
HRDC0R19
Jul 5, 2015 06:43 PM
