noiser after valve adjustment on 22re
Old Feb 23, 2011 | 01:13 PM
bobby_duce's Avatar
so i adjusted my valves. did everything by the book, it was hot and set valves at .008/.012 and it seems like there’s a louder noise now than when I started. Its mostly coming from the middle to the back of the engine. so i know its not the timing
Timing chain rattling around. I doubled check to make sure my valve cover wasn’t to tight and its good. i started to search and i came a crossed this link and i wonder if this is accurate or not...does it take 150-200 miles sometime for the valves to adjust and quite down? i guess it does make some sense but i just wanted some input on this.
http://www.toyotanation.com/forum/sh...d.php?t=371049
if it doesnt go away ill just cold adjust them at .007/.011 and see if it helps at all. thanks for your help!!
Old Feb 24, 2011 | 04:14 PM
bobby_duce's Avatar
just a update i just cold adjusted them at .007/.011 and it turned out very well, its quite again!
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
Gamble_STi
Jul 7, 2015 07:54 PM
