Mystery Idle problem
Idle takes off when clutch pedal is pressed...can't figure it out. I have checked for vacuum leaks, checked timing and so on. The problem seems to be getting worse and its only when engine is cold. I wonder if its a valve clearance issue? Or could it be the dashpot? Any help or advice would be appreciated if anyone has had this problem before.
Jnkml
Jul 6, 2015 01:20 PM
